Drives: 10 series FRS
Trust/Greddy FRS/BRZ/86 Dog Box Transmission
I had the opportunity to test out Trust Racing's new 86 build for Toyo Tires. The car was equipped with a Greddy Performance 2.1L stroker kit, a Greddy T620Z Turbo kit with 550whp, and the revised Trust Racing 6 speed Dog box.
I won't go into too much detail since the photos can tell a lot but the gear set is made to fit in the stock transmission case. With a ton of clutch kicks in 4th and 5th gear on Toyo's sticky Trampio R1R, the gear set was basically unharmed upon inspection. 4th gear is the common culprit for those of us with higher HP numbers and sticky tires. We shaved the reverse gear, and made 4th gear a lot thicker. The gears are helical cut for two reasons. One: its quieter for street use (although i am sure some will say they like the gear whine), and two: helical cut gears are stronger than straight cut gears. Since I am not a vendor here, I won't mention any pricing, but from one fellow FRS owner to others, I just wanted to let you guys know that we now have an option! no more broken 4th gears! You can comment below for any questions, or contact Greddy Performance. Last edited by Knshro13; 12-03-2015 at 12:38 AM. |
| The Following 15 Users Say Thank You to Knshro13 For This Useful Post: | 86drift (01-13-2016), BatStig (01-11-2016), Bonburner (02-07-2016), chaoskaze (02-12-2016), DarkSunrise (12-03-2015), Doozer (01-22-2016), Drakiv (01-22-2016), JDKane527 (12-03-2015), kbye (12-03-2015), MJones_RB (04-06-2016), raven1231 (12-03-2015), swarb (12-03-2015), Ultramaroon (12-03-2015), whataboutbob (02-17-2016), ZionsWrath (12-03-2015) |
#2 |
How long until the Sbd version comes out?
| The Following 12 Users Say Thank You to raven1231 For This Useful Post: | 504 (02-12-2016), Dream20b (01-22-2016), Fakk (02-15-2016), Fred E (12-03-2015), killboy (02-12-2016), mrk1 (02-11-2016), Nessal (02-12-2016), nickmerronesucks (02-11-2016), Nightbringer (07-18-2020), thunderlights (12-03-2015), weederr33 (02-12-2016), wparsons (01-23-2016) |
#3 | |
Proud of BOXER
Drives: Subaru Boxer
#5 |
Turning is for Nerds
Drives: 35 characters is not enough
off topic, but what the fuck is going on with those strut mounts?!? Guessing longer lower control arms and tie rods for more steering angle which necessitates moving the strut more outboard?Got any shots of the front suspension?
#6 |
Junior
Drives: a car
T__________T
You suck
#7 | |
ill upload more photos of the car in a bit. |
| The Following User Says Thank You to Knshro13 For This Useful Post: | Drakiv (01-22-2016) |
#8 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
Finally! I need this set........
#9 |
...Just add nauseum
Drives: 2003 (AP1) S2000
It also relocates the steering rack inside the front crossmember, rather than behind it, and replaces the knuckles.
There are many ways to displace.
-Spartarus |
#10 |
Drives: Moped
A mention and some more pics of the dogbox here:
http://greddy-usa.blogspot.com/2016/...uto-salon.html |
| The Following User Says Thank You to Lonewolf For This Useful Post: | Bonburner (02-07-2016) |
#11 |
Round 3 Racing
Drives: Scion FR-S race car
Trying to get information from Greddy on this dog box has been difficult. Anyone have any info, like price or availability?
#12 | |
Drives: Moped
| The Following User Says Thank You to Lonewolf For This Useful Post: | Knshro13 (02-12-2016) |
#13 |
#14 |
Ive been getting a few DMs regarding this kit.
I am not a vendor nor am i directly selling these gear sets. You guys can contact Greddy at 949.588.8300 and ask for either Mike or Kenji. Meanwhile, here is some info on some questions i have been receiving. Gear ratios for the gears: 1st 2.6805 2nd 1.8514 3rd 1.4017 4th 1.1529 5th 1 6th 0.8716 At this moment, customs gears are not available. You can however order spare gears or misc. replacement parts. Here is a list of OEM toyota parts needed to complete the dog box. These parts are order via Toyota parts department. SU003-03499 6th gear thrust washer SU003-03923 4th gear washer set SU003-03521 3rd gear needle roller bearing SU003-03522 input shaft bearing SU003-03524 6th gear needle roller bearing SU003-03525 counter gear front bearing SU003-03526 output shaft bearing rr SU003-03527 input shaft bearing fr SU003-03550 force washer retaining snap ring SU003-03587 counter gear front bearing snap ring No.1 SU003-03588 snap ring (need 2) SU003-03640 slotted spring pin SU003-03641 gear thrust washer straight pin SU003-03874 gear shift fork shaft no. 5 SU003-03890 force washer retaining ring SU003-03924 shaft snap ring SU003-03925 counter gear front bearing snap ring No. 2 SU003-03926 6th gear shaft snap ring SU003-03927 front bearing shaft snap ring SU003-03928 transmission clutch hub No.3 shaft snap ring (need 2) SU003-03908 1st shift restrict ball Last edited by Knshro13; 02-13-2016 at 08:12 PM. |
| The Following 5 Users Say Thank You to Knshro13 For This Useful Post: | Andew727 (04-12-2016), celek (02-13-2016), Drakiv (02-15-2016), Hawk77FT (02-16-2016), whataboutbob (02-17-2016) |
| Greddy/Trust T518Z Turbo Kit Owners | rocketbunny86 | Forced Induction | 126 | 05-24-2024 04:02 PM |
| Greddy / Trust Turbo Kit (Video and Pictures) | BPAuto | Forced Induction | 62 | 03-18-2016 07:04 AM |
| Opinions Needed on Greddy/Trust Spoiler | Primeraman | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-22-2014 11:09 PM |
| Greddy Trust Wings question | Liselotte | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-11-2014 05:46 PM |
| Greddy Trust Wing | pghfan19 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-31-2013 09:35 PM |
