Old 04-10-2016, 09:40 AM   #1
DaiTT500
DaiTT500's Avatar
Drives:
Broken inner tie rod at the track.
I went off track in a bad spot and broke my inner tie rod end. I've been reading about outer tie rod bump steer kits like SPL and how they can change the geometry to help prevent the weak inner tie rod from breaking so I will be getting something like that but for my broken inner tie rod should I go aftermarket or oem? Only one I see that makes them is Megan and usually I stay away from anything megan but if I want to go aftermarket it may be my only choice unless anyone knows anymore. They advertise it to be stronger than oem. Anyone run the megan tie rods?
DaiTT500 is offline   Reply With Quote
The Following User Says Thank You to DaiTT500 For This Useful Post:
ZionsWrath (04-10-2016)
Old 04-10-2016, 10:02 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
Where is it broken exactly?
Beneath the boot? Are you sure? My boots look retarded like that too lol
Old 04-11-2016, 08:08 PM   #3
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Im shopping for inner tie rods too. Im looking to get OEM, i heard alot of bad experiences thru megan racing products.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 04-12-2016, 10:20 PM   #4
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Do you want to bend an inner end, outer end, end link, control arm, or wheel?
If you go 4-wheelin', it sometimes costs money. Personally, I'd stick with OEM, unless there's an obvious performance advantage that makes sense and that I'm willing to live with (NVH?). I don't know the costs and hassle that figure into your issue, but that's how I'd approach it.
Chalk it up to a wear item and lesson learned.
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline   Reply With Quote
The Following User Says Thank You to jmimac351 For This Useful Post:
e1_griego (04-12-2016)
Fog Lights (OEM FR-S) Broken - Help! cdo221 Cosmetic Modification (Interior/Exterior/Lighting) 1 11-15-2015 08:28 PM
Cat broken apart Frank the Tank Engine, Exhaust, Transmission 3 10-23-2015 03:18 PM
My car got BROKEN into. Hiros86 Northern California 25 02-25-2014 12:33 PM
Still not broken in Drftfan Scion FR-S / Toyota 86 GT86 General Forum 38 06-13-2013 08:51 PM
Broken into sharris721 BRZ First-Gen (2012+) — General Topics 42 04-28-2013 01:22 PM
