Old 03-28-2016, 03:27 PM   #1
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Different wheel diameters' effects on TCS
Right now I have a 235/40R17 square setup. It's great and all, but I need a little more traction out back.
I came across a deal for almost free (good buddy getting rid of one set of track tires for another) 255/40R17 tires.
I was thinking of running the 255/40's out back on 9" RPF1's.
Would the discrepancy between 235/40 and 255/40 be too much for the traction control?
Thanks in advance!
xsnapshot is offline   Reply With Quote
Old 03-28-2016, 04:31 PM   #2
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
You can compare the two using this calculator below. Basically, the calculation shows they are within the 3% tolerance frame that would affect TCS. So no issue.
http://www.1010tires.com/Tools/Tire-Size-Calculator
n8dog11914 is offline   Reply With Quote
Old 03-28-2016, 05:17 PM   #3
xsnapshot
Fast enough
Ya I just am hesitant. A 2.5% difference is not that far from 3%.
I guess I'd like to hear from someone who has run different sizes and had no issues before I go and spend the $ to acquire the 9" rims.
Old 03-28-2016, 05:19 PM   #4
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
i am running 18x9.5 all around with 225/40 front and 255/35 rear with no issues.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 03-28-2016, 06:08 PM   #5
xsnapshot
Fast enough
Yes but you are running 255/35. I am talking about running 255/40.
Old 03-29-2016, 09:13 AM   #6
nickmerronesucks
Ned flanders
my tires are still different diameters height and width, if anything a greater difference then a 40 side wall. So my point was if i dont have issues, you shouldn't.
797Performance.com
Old 03-29-2016, 11:20 AM   #7
xsnapshot
Fast enough
Again....that's not how tires work. A 225/40 has a circumference of 2,002 mm. A 255/35 has a circumference of 1,997 mm. This represents a difference of 0.2%.
My proposed setup has a difference of 2.5%. Over 10 times your difference.
You essentially have identically sized tires. Now they are bigger than stock yes, BUT.....they are basically the same diameter front to back. Your car doesn't care if you have tiny hotwheels tires or giant tractor tires. All it cares about is that all four are the same diameter.
Old 03-29-2016, 12:15 PM   #8
Cole
Not a troll
Cole's Avatar
You could always not run a staggered set-up that would increase understeer.
Cole is offline   Reply With Quote
Effects of wheel weight and width on suspension wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 04-02-2015 12:44 AM
inch escape: effects pepe Forced Induction 8 04-20-2014 02:15 PM
Effects of LED module OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 1 04-06-2014 05:15 AM
effects of elevation StormTrooper Engine, Exhaust, Transmission 1 01-27-2014 01:26 AM
250 ~ 300 hp - Cost, Requirements, Effects Froylavin Engine, Exhaust, Transmission 14 07-19-2012 01:55 AM
