Old 01-13-2021, 10:53 AM   #1
Hamza
Hamza's Avatar
Drives: Widebody 86/F56 Mini Cooper S
Automatic Transmission Shifting
Alright so before I ask the question I'll clarify to avoid jokes
Almost everyday I wish I had a manual, but at the time of buying (used) I was getting a significantly better deal with an auto 86 rather than a manual, so I had to go for it for now (plus I just think manual would be more fun in somewhat powerful cars? let me know if I'm wrong).
So the question: Is there ANY way to switch the upshift/downshift on the lever to downshifts be push forward, and upshift be pull back?? I'm so used to German cars and actually partially lose my mind switching frequently.
And it just makes more sense to upshift by pulling back because if you're accelerating you're meant to be pushed back??
Hamza is offline   Reply With Quote
Old 01-13-2021, 10:59 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
I have no idea if anyone offers something like this, but I would imagine it would be fairly simple to do with a tune (if aftermarket tunes for the transmission exist).
Alternatively, if you're handy it might be possible to swap the shift level wires of the two contacts. You could take off the shifter boot and have a look at the electronics of the shift lever to see if this is something that's possible.
Old 01-13-2021, 11:02 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Why take a good deal if it's not what you want?
There may be a way to change the logic but it's probably far more trouble and cost than it'll be worth. Unsure if tuning software will be able to change that switch function
Hopefully someone will have an answer for you, but I'd try to just get used to it.
I know the frustration; I got used to the tiptronic shifting in E46 BMWs for a bit when I worked in a shop. Going from those to other vehicles, it was backwards and I continually was going the wrong way
Hamza (01-13-2021)
Old 01-13-2021, 11:06 AM   #4
Hamza
Hamza's Avatar
I was thinking of opening it up this weekend and seeing if it can be switched around physically haha
Old 01-13-2021, 11:37 AM   #5
This may help. I have not done it, but it explains it and probably outlines if it was successful.
https://www.ft86club.com/forums/showthread.php?t=21741
Hamza (01-13-2021), mrg666 (01-16-2021), Ohio Enthusiast (01-13-2021)
Old 01-13-2021, 12:37 PM   #6
Hamza
Hamza's Avatar
AHhhhhhhhh thank you bro!! It's exactly what I needed
The Following User Says Thank You to Hamza For This Useful Post:
Dadhawk (01-13-2021)
Old 01-13-2021, 08:34 PM   #7
Z06ZN6
Drives: 2017 Toyota 86
I did this last year. It works great.
Z06ZN6 is offline   Reply With Quote
The Following User Says Thank You to Z06ZN6 For This Useful Post:
Hamza (01-14-2021)
Old 01-16-2021, 12:24 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
My Mazda-3 and FR-S have automatic transmissions with opposite directions for manual shifting on the stick. But I prefer paddles which are in the same position. I never thought about modifying one of the cars. I just do the mental adjustment.
Just like you, I bought the automatic since there was a unique deal. I have no regrets. It is still fun to drive in manual mode.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
bcj (01-16-2021), Dadhawk (01-16-2021)
Old 01-19-2021, 12:33 AM   #9
Hamza
Hamza's Avatar
Yup I don't have regrets, it's just this was going to be like my first actual car so I was dreaming about stick shift for months before xD
I like the paddles on 86 compared to other cars I've driven, but I find it more fun to move the stick back and forth, seems a bit more dramatic haha
theneptune86 (01-19-2021)
Shifting Problem (Automatic) FRSure Issues | Warranty | Recalls / TSB 61 05-09-2021 07:38 PM
Automatic shifting yay or nay? Roopert Scion FR-S / Toyota 86 GT86 General Forum 36 04-23-2020 04:13 PM
Automatic BRZ down shifting eric2523 Engine, Exhaust, Transmission 12 08-20-2015 06:30 AM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
