Old 01-26-2016, 04:25 PM   #1
Tank42
Drives: Fr-s 2014
Dots in coolant(open radiator cap)
Size:  56.0 KB has anyone had this yet in there Frs
Sent from my SM-N915V using Tapatalk
Tank42 is offline   Reply With Quote
Old 01-26-2016, 04:37 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It's buildup from you letting the system go dry.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
FRSBRZGT86FAN (01-26-2016), go_a_way1 (01-26-2016)
Old 01-26-2016, 04:39 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Old 01-26-2016, 04:42 PM   #4
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Apparently they like drinking the coolant also from time to time. Mofokin aliens
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
go_a_way1 (01-26-2016), TRD-X (01-26-2016)
Old 01-26-2016, 04:46 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
give those aliens coolant... aliens love coolant
NyC Zn6 (01-26-2016)
Old 01-26-2016, 04:49 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
-alex
Originally Posted by Tank42 View Post
Attachment 129943 has anyone had this yet in there Frs
Mavs got it right, you should probably flush the coolant and replace with OEM or go the evans waterless coolant route.
Old 01-26-2016, 04:50 PM   #7
Tank42
Drives: Fr-s 2014
So it's normal? So I should just regularly check to make sure the coolant levels are good and the aliens will go away lol
Old 01-26-2016, 04:57 PM   #8
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
In my experience the dots are from
  • Low coolant (check it more often!)
  • Mixing different colants
  • water that is contaminated (such as rich in minerals)
  • Coolant that is a bit worn down or picked up debris from radiator
I would do a coolant flush (aka radiator flush) and every time I would add water, id make sure it was distilled.
Do you drive your car often? Maybe it's just settled debris.
Old 01-26-2016, 04:57 PM   #9
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Have you watched South Park regularly ? And season 19 totally ruled !
Season 19 Episode 4 'You're Not Yelping'. And for those of you in a hurry, it's last two minutes of that show...'The Yelper's Special'.
When a restaurant server gets complaints about the food, must take it back to the kitchen, there's no telling what he/she will do with the food once in the kitchen, before it goes back to the customer.
Possibly a factory worker did the same to your cooling system.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
Old 01-26-2016, 04:59 PM   #10
mav1178
mav1178's Avatar
It may just be buildup at the top of the water neck. Just make sure that 1) your radiator cap is working properly (spring is not stuck), and 2) your overflow tank is not dry.
Minor buildup is not an issue, but over time it will slowly reduce the efficiency of your cooling system.
And as others have said, whatever you do don't just fill it with tap water.
-alex
strat61caster (01-26-2016)
Old 01-26-2016, 05:00 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
You should check coolant fairly regularly as aliens come in the night to drink coolant. If you see one sipping your coolant shoot on site
Old 01-26-2016, 05:02 PM   #12
Packofcrows
Check it every other week. Check radiator cap and also reservoir.
Don't forget to pressure check tires monthly, oil weekly (imo) and just do a simple walk around your car.
Old 01-26-2016, 05:08 PM   #13
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Have the same, wiped it out, will flush at 60k miles which should be about 4-5 years of ownerships, nice to know it was from the time my reservoir was dry.
ineedyourdiddly
Old 01-26-2016, 05:32 PM   #14
Tank42
Drives: Fr-s 2014
The over flow tank was left dry by the dealer I took it too! Fml I trusted them
WTB: OEM Radiator, Radiator Fan Assembly, Airbox, Condenser, Washer Reservoir, Winjet Xanatos Want-To-Buy Requests 1 01-05-2016 03:24 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Addition of a radiator hose sensor temp adapter & coolant bleeding FutureFT86 Engine, Exhaust, Transmission 9 07-22-2014 12:50 AM
Little orange dots on paint White0utFrs Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 20 04-04-2014 09:45 PM
what are the dots for? draggin_az Cosmetic Modification (Interior/Exterior/Lighting) 12 10-24-2012 05:38 PM
