| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
DIY - Drivers Mat Heel pad for only $15
Drivers heel pad - simple solution to make a heel pad for the drivers stock mat that looks fantastic as below for about $15 in total.
![]() One of our 86 club members here in New Zealand, Peter Sullivan (user Tech on the forum now) came up with this brilliant solution and has given me permission to share his DIY writeup with you all. From Peter: I purchased a rubber door mat from "The Warehouse" (this is our cheap general purpose big box store like walmart in the USA) for $9.99 and this was sufficient to make 6 heel pads for the 86 drivers mat. It has raised ridges one side and is PERFECTLY SMOOTH on the other - This is important. The backing needs to be smooth without any dimples or non-slip bits. TIP - have a look at the household rubber mats section of the store rather than rubber car mats as most of the rubber car mats will have dimples etc - the household mats won't. From this I cut a piece measuring 250mm by 150mm using sharp knife. To cut the corners I used an NZ 10 cent piece - the same as an Australian 10 cent piece and similar to a dime in the USA. Use a bigger coin if you want rounder corners and of course feel free to cut into any shape - I just did a simple rectangle. All the marking and cutting was performed on the smooth side of the rubber. ![]() Velcro is extremely good at attaching itself to carpet fibres as shown in this photo. There is only about 60mm of the "hook" side of the Velcro in contact with the carpet, and yet it is strong enough to suspend the whole carpet in the air. ![]() ![]() The Velcro hook is 50mm wide with a self adhesive backing. ![]() Thoroughly clean the smooth side of the rubber with Mentholated sprits to remove any dirt or grease. ![]() Peel off the backing and attach the Velcro. Press firmly on the Velcro for at least 25 seconds. This will give the best adhesion, being a contact glue. ![]() Job done, and it can be moved or removed at any time, but it won't slip underfoot. Thanks Peter!!! ![]() You can get carried away as much as you like and even add a much bigger drivers pad and pads for passengers in the front and rear seats. ![]() ![]() . .
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 Last edited by nzer; 01-17-2013 at 04:58 PM. |
| The Following 18 Users Say Thank You to nzer For This Useful Post: | Anduz (04-23-2013), BigFatFlip (01-04-2013), bpracer (01-01-2013), finch1750 (01-04-2013), Gp1666 (02-01-2013), I<3Twisties (01-19-2013), kombatlion (05-10-2013), leon78 (01-24-2013), Noob4Life (04-15-2013), normancw (01-01-2013), Richard Cranium (05-09-2013), shaoster (01-22-2013), simpleisbest (01-01-2013), Spartan65 (05-09-2013), theurbaninja (07-28-2013), TrickyFrenchman (01-06-2013), whaap (12-31-2012), zoomzoomers (07-09-2013) |
#2 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
That is just great. Thank you and thank your friend. I will probably do this tomorrow.
#3 |
DADA
Drives: 2013
Very nice , alot of people will be doing this I'm air
#4 |
I'm sure he'll appreciate the thanks - might even encourage him to join the forum as he's a handy chap to know!
http://www.ft86club.com/forums/showt...760#post582760 |
#5 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I just happen to have rolls and rolls of that same Velcro at home ... Great idea as I've notice quite a bit of wear in three months
#6 |
Drives: Asphalt FR-S
I had just seen the related post in your regional forum and was going to suggest a DIY entry.
My mats looked bad after a a couple weeks of driving. I may try this.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 |
| The Following User Says Thank You to bpracer For This Useful Post: | nzer (01-01-2013) |
#7 | |
#8 |
Drives: Toyota Black 86 GTS
Great thinking esp with the velcro! Cheers.
#9 |
Drives: FRS
great idea!
#10 |
Drives: White MT GT86 with TRD extras
Hi. I am Peter and also the author of the worn mat solution, posted by "nzer".
Just joined this forum today and hope to get more actively involved as time goes on. Happy new year to you all! |
#11 |
I Void Warranties
Drives: Asphalt 86
This looks very nice, Good job. I think I might try this as well. My mat looks pretty rough after only 4 months of driving.
#12 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
I did this a couple days ago. A $5 generic rubber rear mat from Walmart and some trimming. Working well.
#13 |
I decided that the velcro and rubber solution devise by @Tech was so good that I made a much bigger pad to cover most of the drivers mat but it still looks awesome in the car and a pad to cover where the passenger generally has their feet. They don't move at all when installed with the velcro.
#14 |
So far I've run into a wall here in Az. Admittedly I've only tried Walmart so far but I checked out all their cheap-o mats and they all have nubbing on the back side to help prevent sliding around. I'll have to consider looking for something else or at least somewhere else.
| Difficult to heel toe | NoVtec | Scion FR-S / Toyota 86 GT86 General Forum | 110 | 11-12-2015 06:42 PM |
| Heel Toe Question | trackmagic | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 02-24-2014 01:29 PM |
| Having difficulty heel toe | #87 | Tracking / Autocross / HPDE / Drifting | 25 | 01-27-2014 12:00 AM |
| Heel toe | #87 | Other Vehicles & General Automotive Discussions | 21 | 08-25-2012 06:39 AM |
| Heel and Toe | ichitaka05 | Other Vehicles & General Automotive Discussions | 13 | 04-02-2010 03:28 AM |
