Old 12-21-2015, 02:20 PM   #1
Spencera15
Drives: 2015 Scion frs
Question New member and have a question please
Hey all first off im new here and happy to be apart of this group i have a question tho i have recently just got me the spyder fog lights for my frs and after looking around i can't find a DIY for the spyder fog lights so my question is do any of you guys know if this harness can be hooked up without using the button it comes with?? For example how can i hook up this harness so it comes on with my DRLS?? If needed as well i can post pictures of the harness, Btw i apologize for being a noob at these wiring questions
😂 Thanks everyone in advance
Spencera15 is offline   Reply With Quote
Old 12-21-2015, 02:51 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
�� Thanks everyone in advance
You should be able to just wire the foglight positive into the positive for the DRL's, and ground it and it will work, however they will only be on when your headlights are off (if you are talking about those DRL's in the headlight) or only be on when you turn on your taillights/ low or high beams (I assume that is what you want?)
Old 12-21-2015, 02:57 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Yea you can tap into the side markers so they come on with drl and with headlight. That's how i did mine.
Old 12-21-2015, 03:07 PM   #4
Spencera15
Okay thank you very much for the very quick responses sorry i wasn't to specific my goal is to make it where the fog lights turn on when my other lights on auto turn on so tapping into the side markers would probably be easiest right? Or do you guys have any suggestions to make it easier? Thanks again
Old 12-21-2015, 03:09 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah I would do sidemarkers or something. Just be sure your fogs down draw to much power or your fuse will go but other then that it should be fine. I am sure there is a better way to do it, but I would just tap the side markers myself
Old 12-21-2015, 03:11 PM   #6
Spencera15
Okay thank you very much! Quick question when you did yours did you take the whole bumper off or did you just go behind the wheel well or under the bumper? Thanks
Old 12-21-2015, 03:14 PM   #7
NyC Zn6
NyC Zn6's Avatar
behind the wheel well to get access to sidemarker wiring.
Old 12-22-2015, 11:38 AM   #8
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Same here. I hooked mine up to my side markers so they're on when I turn my headlights on.
I'm using LED though just for looks so less power draw, went through the side wheel wells.
YamahaR86 is offline   Reply With Quote
foglights, question, spyder
New Member & have question? Read here first! ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 153 06-08-2023 11:58 PM
New Member & have question? Read here first! ichitaka05 BRZ First-Gen (2012+) — General Topics 6 10-22-2021 06:43 AM
New Member - paint question kberkel BRZ First-Gen (2012+) — General Topics 21 03-26-2014 10:38 PM
Possible new member agray56 CANADA 3 02-15-2013 12:17 AM
New Member/ Quick question sikse7en Scion FR-S / Toyota 86 GT86 General Forum 3 11-28-2011 09:57 PM
