DEEEERP
Bad Emergency Jack?
I just bought my FR-S yesterday so I haven't needed to use my jack but I saw that someone posted on the BRZ Facebook page that his jack failed after 7 minutes of use!? Luckily he wasn't under his car but still, dude could've died.
UPDATE (10/9/12) here's the pic. ![]() Here's the link: https://www.facebook.com/photo.php?f...type=1&theater Again, im not trying to meddle in anyones business but if the guy had an issue with a piece of equipment im just trying to pass the word.
#2 |
Site Moderator
Drives: ichi 86 Project
More info?
| The Following User Says Thank You to ichitaka05 For This Useful Post: | neutron256 (10-07-2012) |
#3 |
Drives: 86' Toyota Corolla GTSR5, 15' FRS
This is why I keep a hydraulic jack and one jackstand in my car. Spare jack broke on me while my friend and I were being good samaritans. Good thing I had just got the wheel on....
#4 |
Drives: 2013 Raven FR-S
i usually put the wheel i take off under the car when doing a roadside change(in place of a stand, but obv i dont lower onto a wheel lol), or a lift without a proper jackstand. not sure how much it would help in the case of a failure, but it should lessen the blow imo.
| The Following 2 Users Say Thank You to Ravenlokk For This Useful Post: | Brett (10-09-2012), zenki_levin (10-07-2012) |
#5 |
DEEEERP
yea, it is what it is, an emergency jack. i personally have a 3-ton jack in my trunk and would never get under a small jack. i dont have more info other than the direct quote.
"FT86 owners DO NOT USE EMERGENCY JACK! I was using it an hour ago and after 7 minutes of holding the front the all thread bent and my car dropped. I'm just glad I wasn't under there. Will post pics."
#6 |
This is a good example why you should never get under a car with the emergency jack or any jack. Always use proper jack stands on flat ground
#7 |
Señor Member
Drives: 2013 SSM DZE BRZ
This is why it's better to use roadside assistance (AAA et al.) than risk life or limb using an emergency jack. You won't catch me on the side of the road working on my car. Any other time, I'll either be using ramps or a quality jack and jack stands.
#8 | |
Road Warrior
Drives: AE86 Levin
#9 |
Drives: FR-S MT
Who has the room to keep a hydraulic jack in the trunk? Not to mention having it shift around during hard maneuvering? No thanks.
#10 |
You know you want it.
Drives: '13 FR-S
Never get under a car that is supported only by a jack.
I'd recommend calling for a tow or at the least motorist assistance if you are on the road. Working on the side of the road is dangerous stuff, I know.
The Following User _________ Stay_Puft(09-13-2014) Says Thank You to MmmHamSandwich For This Useful Post: |
#11 |
Drives: 2012 FUJI Z
"just" an emergency jack?... well its good to know paramedics don't drive around in emergency vehicles... I sure feel better knowing that people who don't know what they're doing are using equipment that requires expert knowledge in balancing and load distribution in adverse climate conditions, could not possibly see how that could go wrong...
#12 |
Drives: '15 Vortech Supercharged
You wouldn't catch me under my car with nothing but the emergency jack in a billion years. That said, I've actually used mine 7 or 8 times now (I guess my gravel driveway is just filled with old nails) and it's been totally fine.
Anyway, we've all got roadside assistance for the next 2 years or 25,000 miles, so I would recommend just using that. |
#13 | |
DEEEERP
i supposed you've never owned anything faulty, or defective...? comparing a jack to a EMS vehicle, i just dont see the analogy.
#14 |
Drives: 2010 4Runner Trail
Don't depend on the roadside assistance guy to have a proper jack. 11 years ago I had a 99 GTP and saw a fellow GTP owner stuck at the side of the road. I pulled over to help and found out their jack had stripped, then broke while removing a flat tire. The guys said don't wait, they have a tow truck coming to replace the flat tire, but when the guy showed up he didn't have the proper jack at all. We ended up using my jack instead and got the guys tire changed.
Having said that, I had the same GTP jacked up in the driveway and when I jarred the car slightly, the oem scissor jack broke and dropped the car. The dealership replaced the jack for free. Rob |
| $10 Jack Buddies | blalor | DIY (Do-It-Yourself) Guides | 24 | 10-20-2017 07:16 PM |
| usb/3.5 jack relocate + usb charger | BRZranger | Electronics | Audio | NAV | Infotainment | 22 | 11-13-2012 10:42 PM |
| Where ti jack car up at? | skatery1989 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-13-2012 01:53 AM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 11:43 AM |
| Jack Spots? | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 06-11-2012 09:09 AM |
