That Guy
Drives: 2013 asphalt FRS MT
Rigid Collars?
Ok, I'm starting another thread so I don't crash the party in the other thread.
Are these for real? This seems like snake oil to me. I've removed subframes and other than a witness mark from where the bolt head contacted there's no marks at all. If the subframe were moving, even slightly, there would be indications of that, wear patters in the paint. But there isn't. Every time I try to look for a review of these things it's always an overly detailed and long winded review, which leaves me wondering about the motivation of the reviewer. Can any of the OG's on here attest to the effectiveness of these? |
#2 | |
Drives: 2014 Whiteout FRS
Lots of information there, as well as a video. |
#3 | |
Pissin off regressives
Drives: They have engines.
| The Following 5 Users Say Thank You to endless_pain For This Useful Post: | Calum (07-01-2015), Captain Snooze (07-01-2015), hmong337 (07-01-2015), Hyper4mance2k (07-01-2015), WhiteFRS69 (07-01-2015) |
#4 |
#5 | |
That Guy
Here's part of what makes me thing this might be bull shit: Watch the video carefully it's pretty obvious that the cars were originally traveling at different speeds and the video speeds were adjusted to make them look the same. In the bottom image you can see a sort of ghost image as the tire is approaching the bump, but as the car drops off the car drops off the bump the ghosting slows and stops. Also, the two cars aren't perfectly lined up so it's hard to tell, but it looks like the bottom car starts to lag behind more at the end. To me, it looks like they sped the car up a little in the bottom image so it wouldn't come to a complete stop and used the brakes to prevent the rebound. But I'm not a professional. |
#6 |
The subframe is moving because of the softer rubber bushings (you won't see "signs" of wear)... the idea is to remove the slop. I did the whiteline rear and you can ABSOLUTELY feel the difference when you go into a corner. The entire rear end is more planted and solid.
| The Following User Says Thank You to fika84 For This Useful Post: | Hyper4mance2k (07-01-2015) |
#7 | |
Alexandrino_Auto
Drives: series.Blue
Will it make a difference? Probably. Is that difference quantifiable? Probably not.
The Shadetree Project: I turn wrenches
#8 | |
#9 |
Drives: 2015 Subaru BRZ - DGM 6MT
*We have not done any quantitative testing on these and this is not the view of STILLEN*
I have personally driven a BRZ before and after the rigid collar installation. I can definitely feel a difference. It is hard to describe completely, but the car does feel more solid with them and the front suspension felt a little more responsive. SpeedHunters did a review on them as well. Can probably find it with the Googlez
| The Following 3 Users Say Thank You to Mark@S For This Useful Post: |
#10 |
Drives: Raven Fr-S
I don't think rigidity or prevention of movement are the goals of this product at all. From what i understood, the collars center the subframe on its mounting holes, and ensure that the subframe is parallel to the monocoque, which would add symmetry to the alignment. Rigidity would be helped a little bit by pre-stressing the mounting locations in the presence or absence of tolerance stack up.
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
| The Following 3 Users Say Thank You to 200hp/tonne For This Useful Post: |
#11 | |
Every car has a resonance frequency where stuff just... vibrates, and an exhaust helps reveal this vibration. At a certain RPM, you'll notice vibrations. Once rigid collars are in, that RPM where stuff vibrates changes. CSG David's had Rigid collars on his s2k before the FT86 was even around. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | GT86_PRAGUE (07-02-2015), mokinbird87 (11-02-2015) |
#12 | |
Alexandrino_Auto
Drives: series.Blue
That being said, I want some, and I want them now. I'm supposed to get aligned on Friday for the event at Big Willow on 7/11. When can I come pick them up? LOL
#13 | |
The harmonic frequency analysis is so obvious that a quantified log isn't necessary. It's THAT obvious. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Hyper4mance2k (07-01-2015) |
#14 | |
Frosty Carrot
Drives: The Atomic Carrot
It's not going to prevent your front subframe from sliding around, because it's not currently sliding around. The front subframe is rigidly attached, but from people's pictures, it isn't always well-centered. Precisely aligning the mounting points will make your geometry more symmetric. That's a good thing (except for your alignment tech who can't use this as adjustment anymore). 1 mm can be a big distance when you're talking about finicky suspension points. These collars are very unlikely to hurt performance... but there's no guarantee they will help significantly either. The value that a resonant frequency shift presents is up to you.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | CSG Mike (07-01-2015) |
| SPOON rigid collars install | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 137 | 11-16-2015 04:24 PM |
| Need help removing collars off coilovers | DonZilla | Southern California | 1 | 01-14-2015 08:00 PM |
| Fs: brand new pbm subframe collars | Guildjs | Brakes, Suspension, Chassis | 3 | 10-16-2014 09:54 AM |
| T1R Differential Collars | Mikepage | Engine, Exhaust, Transmission | 0 | 05-01-2014 10:18 PM |
