Old 12-18-2014, 09:22 PM   #1
bobacup
Drives: '15 Halo
Helix Side Markers Issue
Hey everyone,
I recently installed the Helix side markers but I'm able to pull the side markers without much hassle. Any ideas what could be wrong? The side markers make a click sound when the clips are in so I thought they were fine but no bueno...
bobacup is offline   Reply With Quote
Old 12-18-2014, 09:45 PM   #2
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Originally Posted by bobacup View Post
Hey everyone,
They suck and I regret my purchase. The A clip is manufactured horribly in a sense that they will not pop in due to irregular fitment. Also the weather stripping comes off too easy and will fry open bulbs such as LEDs. If you don't install them correctly, they'll stick out and look weird. All you can do is to make sure the A clip fits by bending it in weird ways.
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 12-18-2014, 09:58 PM   #3
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
There is a little clip that probably popped out the attaches to the side. I superglued mine on and it fits perfect like a glove.
Top tip: remove the clip thing that sits above the side marker on each side of the car. Now you don't need to remove the side marker from the bumper to pull the bumber off
Canehda is offline   Reply With Quote
Old 12-18-2014, 10:53 PM   #4
D_Thissen
D_Thissen's Avatar
I noticed when you push the lights in, the bumper moves just a little bit. I used a screw driver behind the bracket to stop the bumper from moving when I pushed the light in and I heard the light click 3 times.
Old 12-19-2014, 10:29 PM   #5
bobacup
Drives: '15 Halo
I'll be sure to try this.
And yeah the A clip on the right side marker flew off when I was double checking the fitment. Like what the hell. Only my left side marker has fitment issues at the moment. I'll see how this goes.
Old 12-19-2014, 11:05 PM   #6
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
the clips are cheap.just remove it and drill into them and zip tie your side markers on. if you remove your bumper a lot which i do, it'll break eventually anyway. plus, its more secure and easier to remove.
or just take off the stock clips and swap it if you're adamant about it
Old 12-20-2014, 12:26 AM   #7
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
The clips suck. I went through the cheap ebay ones first and i broke one putting it in and taking it out. Had to super glue it back to the side marker. I bought the helix set and both require quite a bit of effort but it's a weird angle, push the bumper down a little. Once their in, tug on them a little and if they don't slip out, you're good.
cameronjones239 is offline   Reply With Quote
The Following User Says Thank You to cameronjones239 For This Useful Post:
D_Thissen (12-20-2014)
Old 12-20-2014, 01:03 AM   #8
D_Thissen
D_Thissen's Avatar
I had the helix ones, the clips suck. You can pull them out with pliers then glue them back in. Or just get the JDM/EDM ones. Learned the hard way that cheap isn't always cheap
Helix Side Markers plus New SMD style Side markers 86SPEED Groupbuys 143 11-22-2017 07:25 AM
FS: Clear Helix side markers and OEM Amber side markers unlimited86 Exterior Parts (Aero, Lighting, Etc.) 15 07-06-2015 03:27 PM
For trade - Helix smoked side markers t.chk Exterior Parts (Aero, Lighting, Etc.) 6 09-09-2014 09:27 PM
FS GA: Helix Clear side markers/ OEM Amber Side Markers 86TruenoFRS Exterior Parts (Aero, Lighting, Etc.) 1 03-21-2014 07:06 AM
SOLD drewbot Canada Classifieds 13 03-07-2014 09:39 PM
