Old 07-09-2013, 09:50 AM   #1
HaDDeS
Touge worship
HaDDeS's Avatar
Drives: Forester STi SG9
HKS superExhaust + Ecutek Stage 2.
Hi guys, I wanted to share with you the results we obtainted combining HKS super exhaust and Ecutek Stage 2.
First the Exhaust, i'm not sure it is available in the states as is, but in Japan it is the top of the range option for the 86 / BRZ. It is composed as following:
https://www.hks-power.co.jp/product/...ust/index.html
- R-Spec HKS EL header , no cat
- Metalic cat 150 cells Front pipe
- Power Spec-L muffler
The complete package saves a lot of weight (about 13kgs), and is superb quality !! (i know some of you had issues with SPEC-L mufflers. That, i will discuss in the appropriate thread, i've been able to talk to heads of HKS about it and had some answers)
here are some photos to illustrate:
Here a better view of the header and front pipe
And the exhaust fitted on my car
The installation went pretty smoothly, and then began the process of tuning the beast, SCREENpowers took care of it, and i can't thank them enough for the amazing job they did. They are pretty famous, and they prouved again how pro they are.
The Ecutek custom tune they combined with the exhaust had tremendous results on the curves as you can see here:
The torque dip is really well smoothed and even though there is still a "drop" you still have more torque than stock ! and the power band is improuved everywhere to the redline wich was pushed to 7600 rpm.
I couldn't drive it yet, as they are finalising the map and pushing every single details, just as a side note, we changed the spark plugs for better ones in order to maximise our chances for the best tune possible.
The boss said he was really impressed with the results and think this actually a pretty good solution !
As a bonus, here is one of the Tune runs on the dynapack ! too bad this doesn't make any justice to the gorgeous and very loud sound it makes:
[ame="http://www.youtube.com/watch?v=uZUbJaxj2pY"]http://www.youtube.com/watch?v=uZUbJaxj2pY[/ame]
If you have any questions, feel free to ask
HaDDeS is offline   Reply With Quote
Old 07-09-2013, 04:58 PM   #2
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
What a beautiful exhaust.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-09-2013, 05:15 PM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
The relocation of the second o2 sensor to after the cat is interesting!
Originally Posted by humfrz
I'm old and lazy
Old 07-09-2013, 05:32 PM   #4
HaDDeS
Touge worship
HaDDeS's Avatar
Thanks guys, well the relocation makes sense, on the stock setup the sensor is after the pre-cat located on the header.
On the HKS header there is not cat, it then needs to be relocated after the main cat, on the front pipe.
Still should you want to run a "straight" pipe, the Header has "two" holes to put the two sensors on it clever !!! so it is totally possible to run catless without problems relocating the two sensors. Well of course you will still have to tune the ECU. But technicaly, no problems.
Old 07-14-2013, 09:33 PM   #5
welllam
Drives: STi
I have the same thing except the retain the stock muffler. Sound more solid in the cabin, and zero drone and actually nothing noticeable to the passenger. Outside there is barely any differences... In short, performance improve with a low and stock profile. This header and catted front pipe come with certificate of passing emission and noise test. Not sure if this is useful in USA.
I have Vortech supercharger installed and will be further tuned by @Visconti
welllam is offline   Reply With Quote
Old 07-14-2013, 09:37 PM   #6
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
I want that front pipe!
JimmyMac is offline   Reply With Quote
Old 07-15-2013, 12:28 AM   #7
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Hi, I got a pretty similar setup except my front pipe is catless, just dual resonators.
Are you still using the stock overpipe or did you get an aftermarket one, it wasn't mentioned in the original thread.
stevo_12v is offline   Reply With Quote
Old 07-15-2013, 01:24 AM   #8
JimmyMac
JimmyMac's Avatar
The pictures show the stock overpipe. Looks like HKS needs to make one of those too!
Old 07-15-2013, 01:25 AM   #9
HaDDeS
Touge worship
HaDDeS's Avatar
The whole exhaust is HKS , from Manifold to Muffler it is part of what they call "super exhaust" setup.
Old 07-15-2013, 01:28 AM   #10
HaDDeS
Touge worship
HaDDeS's Avatar
here is everything for the exhaust ! ... of course nothing is stock ! Header no cat, Front pipe catted , and cat back ... dunno where you want a "down pipe", , the part between header and catback is called "front pipe"
Old 07-15-2013, 01:38 AM   #11
JimmyMac
JimmyMac's Avatar
Your "overpipe" is still stock. You can see that it's still stock in your 3rd picture. It's the pipe with the heatshield that connects your header to your front pipe. The inner I.D. on the overpipe is just under 2inches or 50mm (I know because I just went outside to measure mine, it's sitting in the car port next to my stock header.)
What I want is your front-pipe. The pipe with the cat and resonator. I'd love to have that one.
Old 07-15-2013, 01:41 AM   #12
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Nice set up!
Evasive Motorsports is offline   Reply With Quote
Old 07-15-2013, 01:43 AM   #13
JimmyMac
JimmyMac's Avatar
FRS/BRZ exhaust goes as follows:
Header--Over-pipe--Front-pipe--Catback (or Center Pipe and Muffler or Axle Back)
Old 07-15-2013, 01:50 AM   #14
HaDDeS
Touge worship
HaDDeS's Avatar
My humble excuses LOL totally forgot bout that litle dude in the midle !! C*** !!! well yes in that perspective , it is stock :OP indeed.
Question is, should i get rid of it, hum will question that to the right people, well for sure its design isn't ideal at all stock, will it make that much of a difference over the full exhaust I dunno ... worth investigating for the next step maybe. thanks for pointing that out !
Revolutions Performance Stage 1 Ecutek tune Those Meddling Kids Engine, Exhaust, Transmission 2 07-06-2013 11:07 AM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
FA20CLUB.com Stage 1 ECUTEK Reflash SALE FA20Club.com Engine, Exhaust, Bolt-Ons 52 09-23-2012 08:30 PM
Stage 1 93 or E85 Octane ECUTek tunes Available in Miami Bill@SiR Engine, Exhaust, Bolt-Ons 0 08-30-2012 03:45 AM
FA20CLUB.com Stage 1 ECUTEK Reflash Results FA20Club.com Engine, Exhaust, Transmission 20 08-25-2012 07:02 PM
