Old 08-29-2013, 09:22 AM   #1
The RZ Precept
The RZ Precept's Avatar
Drives: Whiteout - FRS/86
ViciousLED FRS Signal LED DRL help!
So I purchased the FRS Turn Signal LED lights with the built in DRL strip, from Vicious LED. I have both lights installed with the hyperflash relay. The turn signals work fine, however the DRL/LED strip do not. The instructions are vague, but it states splice the yellow wire (from the LED lights) to a DRL power connector, which wire is it? Anyone know?
FYI, I already attempted to use the power source from and to the headlight DRLs. No luck.
The RZ Precept is offline   Reply With Quote
Fuel cut or bad ecu signal? love 4 boost Issues | Warranty | Recalls / TSB 8 07-02-2013 04:20 PM
MAF signal sw20kosh Engine, Exhaust, Transmission 1 05-31-2013 01:35 AM
Signal Lights kchkwan CANADA 4 05-25-2013 11:26 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 04:32 AM
