Old 04-18-2014, 02:02 PM   #1
WNDSRFR
Drives: FR-S,GTI
Your stock exhaust manifold revealed
I recently installed the Open Flash Header on my car and thought I would share these photos.
This is the lump as it comes off the car.
The Following 4 Users Say Thank You to WNDSRFR For This Useful Post:
bedabi (04-20-2014), Mikem53 (04-18-2014), Mikepage (04-25-2014), PureShield (01-14-2016)
Old 04-18-2014, 02:05 PM   #2
WNDSRFR
Drives: FR-S,GTI
Here is the heat shield removed.
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
Old 04-18-2014, 02:07 PM   #3
WNDSRFR
Drives: FR-S,GTI
And here are the parts of the heat shield.
bedabi (04-20-2014), humfrz (04-19-2014), Mikepage (04-25-2014)
Old 04-18-2014, 02:16 PM   #4
WNDSRFR
Drives: FR-S,GTI
As you can see the header is really not that bad a piece of work.
It is actually welded tubing rather than stamped steel as I expected it to be.
This may be why massive gains are not being seen with aftermarket headers. Because the stock one is really not that bad.
Another thing to notice is there is foam between the heat shield and the header. I'm guessing that this is the prevent rattling.
One thing you really have to think about is:
If Toyota went though all the trouble and expense of making this heat shield it must be there for a reason. (To prevent fires maybe?).
I think I'm going to wrap my header tomorrow.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
fooddude (04-18-2014), JW89225 (04-19-2014)
Old 04-18-2014, 02:30 PM   #5
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Thanks for taking the pictures to share. Please let us know what you think about the wrap!
leicaboss is offline   Reply With Quote
Old 04-18-2014, 02:50 PM   #6
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Very true. This looks much nicer than '90s cars and Honda manifolds that were a huge, ugly, cast iron brick that weighed 1000 lbs lol.
If this was stainless, shiny, smoothed joint connections, no heat shield, etc..it could easily pass for an aftermarket header..maybe borla or something.
fooddude is offline   Reply With Quote
Old 04-18-2014, 03:06 PM   #7
reeves
While the stock header isn't a bad piece, a good aftermarket header + tune should still give you a better torque curve and a significant bump where the stock torque dip occurs.
Old 04-18-2014, 03:10 PM   #8
ramiram1984
Drives: 2016 STi DGM
Yea other forum members have already done this. sweet.
you can guy that cat out.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 04-18-2014, 03:11 PM   #9
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
I'm impressed that the stock header is a stepped one (4-2-1) which is better then a 4-1 header. The only thing I think would make the stock header better is the size of the piping. Really this is a good stock header, all things considered.
kurbkilla is offline   Reply With Quote
Old 04-18-2014, 03:40 PM   #10
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
not should.. they do!
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 04-18-2014, 03:47 PM   #11
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
yeah i agree with others. one of best good STOCK header i ever seen.
Old 04-18-2014, 03:51 PM   #12
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
It seems like the cat is the biggest drawback
Gilwith1l is offline   Reply With Quote
Old 04-18-2014, 04:10 PM   #13
FR-S Matt
Mine went to the garbage can somewhere....
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
JMon85 (08-13-2017), Mikem53 (04-19-2014)
Old 04-18-2014, 04:39 PM   #14
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
anyway you can measure the size of the ports on top, and also the exit port from the cat? thanks
malubawla is offline   Reply With Quote
HKS Boxer Spec UEL Exhaust Manifold brz_star21 Engine, Exhaust, Transmission 73 02-06-2022 01:14 AM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Straight Manifold back exhaust (Kinda) SmsAlSuwaidi Engine, Exhaust, Transmission 6 11-25-2013 10:25 AM
Stock manifold changing collector Djen Engine, Exhaust, Transmission 7 06-15-2013 03:23 AM
Need factory exhaust manifold dorifuto Engine, Exhaust, Transmission 1 01-24-2013 02:05 PM
