Old 08-27-2012, 09:11 AM   #1
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
My CEL went off now, dealer said nothing they can do
I got 240 miles on my FRS with idling and CEL problem sun. This morning CEL was on, now it is not on. Called dealer and they said there nothing they can do if CEL is off. What should I do?
speedy racer is offline   Reply With Quote
Old 08-27-2012, 09:14 AM   #2
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Looks like you'll need to drive it and wait for the CEL.
kwood9000 is offline   Reply With Quote
Old 08-27-2012, 09:19 AM   #3
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Connect an OBDII scanner and see if the code is stored.
-Justin
Justin.b is offline   Reply With Quote
Old 08-27-2012, 09:23 AM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If it stores the codes, a regular scanner will not be able to find it.
OP: you can hit up an auto parts store and see if you have any "pending" codes, but there's no guarantee that if there is one that it is the same issue.
Next time your CEL comes on, just have your code read at an auto parts store and write it down. That way, if it goes off you can still reference the code when you talk with the dealership.
Old 08-27-2012, 09:35 AM   #5
Justin.b
I'm pretty sure mine reads stored/pending codes and the freeze from the failure. I haven't tried it on the FR-S, but I have pulled this info from other cars (had a weird misfired that would only seem to act up right before inspection time.... what a pain).
-Justin
Old 08-27-2012, 09:44 AM   #6
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Many OBDII scanners will read stored codes, and errors that don't meet the threshhold needed to turn on the check engine light.
In addition there is a separate system accessible by software/hardware like Techstream (which the dealer has) that goes through the same OBD2 connector, but works on a different bus that will show errors even after they have been cleared by normal OBD2 scanners.
Old 08-27-2012, 12:21 PM   #7
xravexboix
xravexboix's Avatar
Drives: 12 Camry Hybrid on 19" RE30
Send a message via AIM to xravexboix
Was there a major temperature difference? Did you just fill gas in the car before it came on?
Usually if it's on then turns off the next time you start it, it could be an evap system related item (ie gas cap not tightened right/gasket on it is bad is the most common one). If it's something bigger, it definitely won't clear itself unless it was just a hiccup in the system to start with.
xravexboix is offline   Reply With Quote
Old 08-27-2012, 09:46 PM   #8
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
The dealer can read codes that are no longer active. Find a better dealer.
Old 08-27-2012, 10:02 PM   #9
tonyho18
Drives: 2006 lexus is250
PSHHH....
Call the dealer and tell them Your less then 300 mile brand new car's CEL came on and your very concerned.
-and yes they can see History codes.
tonyho18 is offline   Reply With Quote
Old 08-27-2012, 10:19 PM   #10
speedy racer
Dealer`s reply its under warranty, typical Burton Smith dealership. Plus I didn`t buy from them bc doc fees 750.
Old 08-27-2012, 11:05 PM   #11
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Record a video . Threaten dealership that it's going on youtube that they won't help you
If it was a BRZ I'd say contact Subaru of America, so whatever the Scion equivalent is should be contacted. My guess is they would "lean" on the dealership to help you.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 08-27-2012, 11:28 PM   #12
xpicer
xpicer's Avatar
Drives: 2013 frs white out
Cool
Easyyy there!!! Everyone wants to blast the heads off the stealer ships!!! Well to the original poster: i understant your frustration that your mil, came on at such an early stage of your ownership, how ever as we "all" know theres is thousands of codes and reasons why the mil could come on. Even a loose gas cap, pr filling up the vehicle with the motor running or the key on the on possition, could cause the mil to come on. So dont panic. Now was your service adviser a retard for telling you there is nothing they can do?? Well YES !!! Because the computer records these soft codes in the memory / history . So next time you call them ask them to give you a print out o the history dtcs of the ecm. How ever if u by mistake left the gas cap loose an or put gas while the engine was running then i wouldnt worry so much since you will probably have some false evap codes that set during the event. Good luck and dont go too crazy before you get the history dtcs.
xpicer is offline   Reply With Quote
Old 08-27-2012, 11:39 PM   #13
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Originally Posted by tonyho18 View Post
PSHHH....
Exactly. So long as you didn't pull the battery, the code will be stored.
Jordo! is offline   Reply With Quote
Old 08-28-2012, 09:18 AM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
JUst call the next closest Scion dealer. Warranty work is honoured anywhere in the country of purchase. In the meantime see if the light doesnt go on again, try opening the gas cap and see if it goes on. If the engine seemed to be running fine it could be something along the lines of the gas cap. If its the cam sprocket thing it's bound to come on again.
Would you buy a car from a dealer that stuck a dealer (ad) plaque or sticker on cars? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 49 04-29-2013 03:37 PM
Servicing my FR-S at Subaru dealer rather than Scion dealer dnL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 08-28-2012 07:25 AM
what's the dealer trying? frs Scion FR-S / Toyota 86 GT86 General Forum 3 07-07-2012 02:01 PM
help with dealer wallace03 BRZ First-Gen (2012+) — General Topics 4 06-12-2012 12:53 AM
NC BRZ available, going with a different dealer Thongpocket BRZ First-Gen (2012+) — General Topics 6 06-11-2012 09:56 AM
