Drives: 2013 Whiteout FR-S
Cruise Control with Aftermarket Steering Wheel **SOLUTION**
So I've read a few posts on here about how people don't want to lose their cruise control functionality with getting an aftermarket steering wheel. Or if you're like me, you just want the functionality of being able to switch maps on your EcuTek tune.
I'm about to retune the car since I'm done breaking in the rebuilt motor.. I was trying to think of a way to retain it when it dawned on me. I have no need for the TRAC/VSC buttons by the shifter. Especially since I have the @Beastronix module (which is an amazing piece of technology if you haven't tried it!) and he's been a HUGE help with all of his knowledge of the twin's wiring and electronics!My friend Paul and I decided to utilize the TRAC/VSC buttons as the cruise control buttons, and no one would even be able to tell. Simple and clean. We've both been quite busy but we have just now finding time to get this project started. I bought a spare cruise control stalk and a spare TRAC/VSC unit from an automatic FRS. Why automatic? Because it has an additional button/toggle for "SPORT" and "SNOW" mode. The only issue with having a MT FRS and using the AT unit is that it has two extra wires and pins inside the connector for the sport and snow modes. So right now the only challenge is finding the right pins to put into the connector. We plan to use the sport and snow modes as the +Res and -Set modes. The TRAC button will be used as the Cancel mode on the cruise control stalk and the VSC button will be used for the On mode for cruise control. We're hoping to get this done fairly soon (hopefully by the weekend or early next week). After we test it out and everything looks good, I'll probably find a way to make it look a little nicer with labels for cruise and some arrows pointing up and down and cancel lol but that's the last thing on my mind for this project. Let me know what you guys think or if yall have any suggestions to make things easier or simpler.
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread |
| The Following User Says Thank You to pleong For This Useful Post: | Beastronix (01-11-2016) |
#2 |
#3 |
Drift Specialist
Drives: 180SX,GT86
![]() I'm in the process of making a few of these
| The Following User Says Thank You to GT86drifter For This Useful Post: | mmmcambelsoup (10-07-2015) |
#4 |
Attached is the design of my bracket (pdf).
It can simply be sandwiched between steering wheel and steering wheel adapter, doesn't crush any cables, doesn't affect any horn buttons and keeps the cruise control lever inline with the vertical axis. http://www.ft86club.com/forums/showt...12#post2412512 |
| The Following User Says Thank You to rx3 For This Useful Post: | mmmcambelsoup (10-07-2015) |
#5 |
hella stock
Drives: BRZ Limited
I like the idea. Definitely keep us posted.
mods & accessories:
beat-sonic shark fin | raceseng apex r limited green | perrin intake | E85 | RS*R Super Down sus | Cleib CF Lip | STi Side Skirts | Rays Gram Lights 57DR |
#6 |
Legend
Drives: BRZ Limited
Instead of a bracket, I made buttons and figured out the ohmage for all the resistors used to make my own chipset and put buttons on the steering column cover for cruise control. It looks a lot cleaner than the bracket that protrudes out like crazy.
| The Following 4 Users Say Thank You to Spinning Sushi For This Useful Post: |
#7 |
Sorry, I've been so busy..
I actually got this done and figured out.. I did the same thing @spinning_Sushi did, but instead I used the trac/vsc buttons from an automatic FRS, since it has 4 momentary buttons. [ame="https://www.youtube.com/watch?v=VgKLJZlznBY"]FR-S Trac/VSC Rewire Cruise Control Function - YouTube[/ame]
| The Following User Says Thank You to pleong For This Useful Post: | Dadhawk (01-12-2016) |
#8 |
Drives: FR-S 10 series
@Spinning Sushi damn i wish you were near me, I'd pay to have you set that up for me.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
#9 | |
Legend
Drives: BRZ Limited
[ame="https://www.youtube.com/watch?v=s187aqlbJEw"]BRZ Cruise Control Relocation/Rewire - YouTube[/ame]
#10 | |
Legend
Drives: BRZ Limited
| The Following 2 Users Say Thank You to Spinning Sushi For This Useful Post: | MalcolmHimself (02-01-2016), mmmcambelsoup (01-13-2016) |
#11 | |
I have the Beastronix 86Nanny, so I had no need for my Trac/VSC buttons.
| The Following User Says Thank You to pleong For This Useful Post: | Beastronix (01-13-2016) |
#12 | |
Sent from my XT1585 using Tapatalk |
#13 |
Drives: Scion Frs
Cruise controll
Hey man ive been lookin for this method for using another method of switching maps besides the defroster.. would you inform me how to connect the pins together for the AT trac control?
#14 |
Old thread but sharing some details from my DIY attempt inspired by the thread / YouTube video.
I bought a used cruise control stalk from eBay, dismantled it, then took the multimeter to it. Resistance readings I got were: 240Ω, 390Ω, 910Ω I'm no electrical engineer, but learned what "current sensing" circuit is and how pressing each button and closing circuit results in different states based on resistance values (ON/OFF = ∞, RES + = 240Ω, SET - = 630Ω, CANCEL = 1530Ω or 1.53kΩ) - very neat-o List of supplies I used: - Buttons - https://www.amazon.com/dp/B0C3GQZQHH...roduct_details - Solderable breadboard - https://www.amazon.com/dp/B09WZY8CFV...roduct_details - Screw terminal - https://www.amazon.com/dp/B088LVP6ML...roduct_details - 20gauge wire - https://www.amazon.com/dp/B089D375K7...roduct_details - Resistor set - https://www.amazon.com/dp/B098BKR447...roduct_details The mess: I tapped into the car-side blue/white, blk/white wires located in the connector hidden under the steering column cover. Reference #5 from this DIY: https://www.ft86club.com/forums/showthread.php?t=101257 👍: Video of final product: |
| The Following 2 Users Say Thank You to waterpanda For This Useful Post: | bcj (07-05-2023), RedReplicant (07-05-2023) |
| Cruise control bracket for aftermarket steering wheel | rx3 | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 07-08-2021 01:26 AM |
| How do you keep cruise control with aftermarket steering wheel??? | kylefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 04-06-2016 06:58 AM |
| Cruise control wont set after clutch install? ($$ reward for solution!) | bren5279 | Issues | Warranty | Recalls / TSB | 18 | 12-05-2014 11:21 AM |
| How do you keep cruise control after installing a aftermarket hub and steering wheel? | Timtamtt | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-30-2013 08:17 AM |
| Aftermarket cruise control... anyone? | Yamajee | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 05-10-2013 07:18 AM |
