| Software Tuning Discuss all software tuning topics. |
Drives: 2013 FRS
Hi guys,
As some may know from our Facebook page, we have been working on integrating a wideband o2 sensor to the OpenFlash Tablet. And it works great. Right now we are just trying to source some connectors so that it can be 100% plug and play. Currently we are just replacing the secondary o2 sensor with a Bosch Wideband o2 sensor (LSU4.2). It plugs into a wideband controller. And that will hopefully plug right into the secondary o2 sensor connector once we source the needed bits. We have added a "Wideband AFR" channel to the OFT logging that converts the analog output of the wideband controller to AFR. As you can see from the following graph, the factory AFR and Wideband AFR reads very similarly until exhaust temps begin to rise (high high RPM WOT). At which point the factory o2 sensor reads leaner than they really are (which is certainly on the safe side of things): http://www.datazap.me/u/shivvishnu/o...12&zoom=14-135 ![]() ![]() This secondary o2 bung location is ideal for those with cat-less headers (like the OFH) since it is recommending that no cat be upstream of the wideband sensor. For those with catted headers, it is recommended to install the WB sensor just upstream of the cat using the supplied weld-in bung. I should have word on the plug-n-play connectors later this week. At which time we will be able to give release date estimates and prices. But expect it to cost around $200 for the OFT wideband kit. In the meantime we will be fine tuning the calibration to ensure best possible accuracy ![]() Cheers, shiv |
| The Following 19 Users Say Thank You to Shiv@Openflash For This Useful Post: | 86-tundra (03-26-2014), alexand3r (03-26-2014), Burn (03-26-2014), CARNZ (03-26-2014), DAEMANO (03-26-2014), DustinS (04-23-2015), eurominican (05-22-2014), forzajuve (03-26-2014), glorydays (03-26-2014), gonzo (03-26-2014), hmong337 (06-22-2014), jbravo373 (03-26-2014), JS + BRZ (03-26-2014), Luckrider (03-26-2014), Lytheum (03-26-2014), Namuna (04-09-2014), steve99 (03-26-2014), Tbor (03-27-2014), trigger happy (07-30-2014) |
#2 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
This is awesome news. It is also nice to see so real confirmation about the accuracy of the factory unit. Is this just you preparing that next step for your turbo shop car?
| The Following User Says Thank You to Luckrider For This Useful Post: | 86-tundra (03-26-2014) |
#3 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Great job! Will the ecu then use the wideband data in place of the primary sensor? Will you be able to provide the logging address for this data, for those of us who also log with tactrix?
- AdrianG |
#4 | |
Drives: FT86
Hi Shiv, I noticed that the Primary open loop fueling AFR Target in tables is about 12.5. However in a couple of post you say you target 11.6-11.8 AFR at WOT on Gasoline. Most peoples logs show AFR in mid to high 11 for AFR. And low LTFT. Jusr wontering why its not closer to target in Fueling table ie 12.5 Is this due to the inaccuracy of stock o2 sensor you talk about above. Thanks Steve |
#5 |
Drives: 2007 STI Limited / 2014 BRZ Limited
Obviously this is not needed for everyone. I assume this is to be able to get the best target AFR for optimizing power by not relying on the more inaccurate factory sensor. Will you be using this info on your logging to optimize the of the shelf tunes? Or is that a bad idea as those of us with the OEM sensor will see a different reading? Sorry if I did not word that appropriately.
#6 |
Fanboy
Drives: 2013 ultramarine frs
@shiv@vishnu is this ~$200 to include the sensor as well?
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#7 | |
[ame="http://www.amazon.com/Innovate-Motorsports-3737-Wideband-Sensor/dp/B000COBT9A"]Amazon.com: Innovate Motorsports 3737 Bosch Wideband O2 Sensor LSU4.2: Automotive[/ame] |
#8 |
Fanboy
Damn wide bands have dropped in price! Awesome
#9 |
Drives: 2015 WRX
I'm curious how well the wideband will accurately read with the OFH since there is an extension in the place of the secondary sensor.
#10 |
Drives: 2013 FRS
Not an issue. In fact it's desirable to have the tip of the sensor flush with the inner surface of the pipe or even recessed a bit for better heat protection/longevity. Recessing it more will theoretically compromise response time but I have not seen any evidence of that be an issue when logging at 13hz.
#11 |
Drives: FR-S Whiteout
Alright!
#12 | |
Drives: FRS
Curious about this as well... |
#13 |
Grip>Slip
@shiv@vishnu - any chance you'll be selling just the harnesses sans sensor? I'd like a way to tidy up my existing wideband install.
#14 |
Drives: UK GT86
Will this support any wideband O2, for those who don't want a Bosch LSU? Also, which wideband controller are you using as this is a big factor in how well the sensor works and lasts?
.: Stealth 86 :.
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 11:12 AM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 12:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 09:05 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
