Boosted Member
Drives: 2013 Subaru BRZ
CEL P0018 Cams
Got P0018 leaving work today. Car seemed fine though, granted I babied it home just in case. I pulled the battery, reset, and the code is gone.
I haven't actually drove it around for an extended period to see if it stays gone.. but from everything I have read - P0018 was an ECU issue that was resolved a while ago? And, I am on an aftermarket tune anyways..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#2 |
Drives: BRZ DGM Limited
Cam issues seem to be an on going problem with these engines. And from what I am reading, they seemed to be linked with engine oil starvation and then engine failure.
Check out this video and go to the 5 min mark and listen to what these guys say about the weakness of these engines. They mention the code you and others have had. Sucks |
#3 |
Drives: Scion FRS 10 Series AVO Turbo
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
#4 | |
Interesting. Is it worth getting a tune on a stock BRZ to improve some of these issues ? If so, is it DYI or do you need to bring the car to a shop? |
#5 | |
Boosted Member
#6 |
Boosted Member
Update (or lack thereof)
After resetting my ECU, I drove it around for about 15 minutes this morning and all seems well. No more code. ![]() I am still paranoid. It happened when I drove off and my engine was cold still, I never do that but yesterday I had to (engine oil was still at <40f). I am wondering if that was a factor?
#7 | |
The posting by AVO seems to suggest there could be a mechanical problem with the cam. Some spring that does not go flush and can cause a code and oil starvation? No idea how you would know unless one takes a direct look at the cam. |
#8 |
Boosted Member
I may be reading this wrong, and their isn't much info out there, but I am under the impression that 0018 and 0019 are ECU-related. Even the post linked above seems to state that, saying that 0016 and 0017 are mechanical-related.
#9 | |
Not sure if the specific Cam code can delineate between ECU cam issue and a mechanical issue of the cam. Maybe someone with more knowledge knows the answer. Anyone know? |
#10 |
Boosted Member
Bump.
This code keeps returning at random. The car drives 100% normal (cruising, 10+ psi boost full throttle, cold start, warm start) until it throws the code, and then it goes into some sort of limp mode until I reset.
#11 | |
Drives: FT86
think post here is the one http://www.ft86club.com/forums/showp...postcount=2970 its supposed to look like this http://www.ft86club.com/forums/showp...postcount=2973 |
#13 |
Boosted Member
TSB doesn't help since I am turbo'd. That battle with the dealership isn't even worth the effort.
More info however.. I have narrowed down when exactly my CEL is triggered. Whenever I let off the gas while in gear or apply a tiny bit of gas while in gear coasting down a hill. Idle is fine. To the floor at 12psi of boost is fine. Cruising is fine. Let off the gas in gear to coast down a hill - CEL. And once the CEL is triggered the car drives like shit. ![]() I suppose I need to start looking into what exactly I need to replace.
#14 | |
Sideways and Smiling!
Drives: Scion FR-S
| The Following User Says Thank You to Darryljr11 For This Useful Post: | woode (02-05-2015) |
| CEL P0018 | brichard0625 | Issues | Warranty | Recalls / TSB | 8 | 02-10-2016 10:44 PM |
| Cams | Fabron757 | Forced Induction | 10 | 01-13-2015 07:30 PM |
| HKS cams | JesseTheFlash | Engine, Exhaust, Transmission | 4 | 01-09-2015 08:42 PM |
| Wtb oem cams | midnight23 | Want-To-Buy Requests | 0 | 03-19-2014 01:07 PM |
| Cams | Surok | Engine, Exhaust, Transmission | 10 | 01-01-2013 09:30 PM |
