Drives: Totaled 2013 Toyota Corolla
HKS GTIII RS Turbo Build Help/Advice
Hello FTFam!
I’m in the process of going turbocharged and I want some advice on parts. I want to know if I’m under doing or overdoing any parts here such as I beams vs H beams being overkill. My horsepower goal is 400whp so I will be building the engine, I will also be running E85 pretty much exclusively so if the Flex Fuel kit from Delicious Tuning isn’t required let me know. Here’s the part list: Turbo Kit Price Match https://www.discountbandit.com/hks-8...-kit.html?gs=1 $3978.47 SB8-XTSS ACT Clutch https://frsport.com/act-sb8-xtss-xt-...h-kit-fr-s-brz $672.00 HKS Oil Cooler 15004-AT011 https://www.hptautosport.com/product...ant=6766221313 $692.29 Radium Engineering 20-0103 - 13+ Scion FR-S / Subaru BRZ Dual Catch Can Kit https://www.cspracing.com/radium-eng.../baja-20-0103/ $379.86 HKS M-Series Super Fire Racing Spark Plugs HL Type Heat Range 10 https://www.vividracing.com/-p-15110...hoCmmUQAvD_BwE $25.89 BRZ/FRS/86 3-PORT EBCS & HKS https://www.delicioustuning.com/node/367 $149.95 DW 9-307-1010 DW300C Compact Fuel Pump w/o Mounting Clips w/ 1010 Install Kit https://sportcompactwarehouse.com/dw...D=pwf462546g1& $151.41 Injector Dynamics USCAR to Denso PnP Adapter https://www.autohance.com/deatschwer...BoCIY0QAvD_BwE $12.00 INJECTOR DYNAMICS ID1050 INJECTORS SUBARU BRZ / FA20 2.0L 11 MACHINED TOP WRX-16B BOTTOM ADAPTORS https://emnotek.com/products/injecto...xoCfUsQAvD_BwE $520.00 Omni Power MAP Sensor for BRZ S2000 K-Series (Black) https://stmtuned.com/products/omni-p...32668938928213 $116.99 BRZ/FRS/86 FLEX FUEL BLUETOOTH KIT MK1 https://www.delicioustuning.com/flexfuel $595.00 Manley I-Beam Turbo Tuff Rods for FA20 BRZ/WRX https://stmtuned.com/products/manley...23354783039573 $865.57 ACL Rod Bearings https://www.maperformance.com/produc...xoCdZcQAvD_BwE $31.58 JE Forged Pistons 86mm 10.5:1 Compression Ratio https://www.oakos.com/JEP-315117.htm $580.37 I need some gauges of course any recommendations on those? I’ll probably have to replace the CV joints as well since this is a good jump from stock, I’ve heard mixed reviews about the Driveshaft Shop Pro Level kit. Any help would be appreciated, I’m working with Kinetic Autoworks in MD but if anyone has any recommendations for the tuning and labor let me know as well. |
#2 |
Drives: Bone stock
Just buy a Iag stage 2 short block my guy if you're going to do pistons and rods.
Sent from my SM-G998U using Tapatalk |
#3 |
You think it's gonna be cheaper or is it just a better option? I don't have anywhere to store my OEM block.
#4 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Some companies will take the core. i.e. your oem block and reuse it
#5 | |
Drives: Crapcan
If your engine is in decent shape you could still sell the short block and recoup a good chunk of money.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (04-13-2021), ICauseCalamity (04-14-2021) |
#6 |
Doing the IAG Stage 2.
| HKS GTIII Turbo vs. Jackson Racing C38 | ICauseCalamity | Forced Induction | 17 | 04-09-2021 03:11 PM |
| First time FRS build looking for advice/ideas | FT86Hypnotic | Mid-Atlantic | 31 | 12-10-2015 04:18 PM |
| Need AutoX Build Advice | muffinz | Tracking / Autocross / HPDE / Drifting | 32 | 09-12-2014 02:27 PM |
| Boombacloud's BRZ Audio Build...Need Help/Advice | boombacloud | Electronics | Audio | NAV | Infotainment | 1 | 12-28-2012 01:35 AM |
