Old 05-10-2020, 07:12 AM   #1
grumpysnapper
grumpysnapper's Avatar
$17000 dampers vs $200 sway bar
Finally had a chance to have my suspension/driving guru take a long hard test drive with the custom Öhlins TTX/TPX dampers, over the sorts of roads that they were developed for.
After returning from the drive loop, he hopped out and said "look the dampers are absolutely amazing...but somethings not quite right".
My heart sank.
But on hearing that I had kept a hollow 18mm adjustable rear bar fitted, he smiled and said that's your problem..."just throw it away and refit the standard bar!".
Two days later on the same loop, he jumped out with a huge smile and said "that car is an absolute delight....I just wanted to keep driving all week"
Basically the new dampers and springs can do much more of the 'work', much more precisely, and independently from each other.
Stiffer sway bar, less compliance.
So the moral of the story is that even 'mega' dampers can be compromised by a sway bar. My friends view is that ideally in a perfect world you should not need a sway bar, and that it is in itself a very agricultural solution to what is usually a complex problem... in other words its at its most useful at a fine tuning level.
(NB this is only relevant to this car's (rough, fast) road driven development, I'm sure there are many other thoughts and practices with sway bars that are also legitimate)
grumpysnapper is offline   Reply With Quote
The Following 6 Users Say Thank You to grumpysnapper For This Useful Post:
bcj (05-10-2020), Code Monkey (05-10-2020), glhs386 (01-09-2023), Pat (05-10-2020), soundman98 (05-10-2020), why? (05-10-2020)
Old 05-10-2020, 07:15 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
The dampers gold plated by any chance?
The Following User Says Thank You to JD001 For This Useful Post:
manualmotive (09-20-2021)
Old 05-10-2020, 07:21 AM   #3
grumpysnapper
Ha...sort of...
The Following User Says Thank You to grumpysnapper For This Useful Post:
daskaman (05-10-2020)
Old 05-10-2020, 07:31 AM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by grumpysnapper View Post
Ha...sort of...
They deserve to be on show in something like this not hidden deep in an ugly wheel well:
The Following 2 Users Say Thank You to JD001 For This Useful Post:
grumpysnapper (05-10-2020), soundman98 (05-10-2020)
Old 05-10-2020, 10:49 AM   #5
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
What front bar do you have on it?
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 05-10-2020, 12:30 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
My heart sank.
so what change did the aftermarket bar make? was it stiffer or less stiff?
i've read of a similar sentiment in other suspension posts, where people get fixated on controlling body roll in corners, and start trying to to beef up the sway bars to counteract the physics of body roll without taking any time to understand how it negatively affects specific corner dampening that can have a much larger effect on overall performance.
Opie (05-11-2020)
Old 05-10-2020, 12:47 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
18mm hollow would be stiffer than stock.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Old 05-10-2020, 01:46 PM   #8
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
In an ideal world, wouldn’t active dampers dynamically reduce roll by increasing dampening on the inner wheels and reducing rebound on the outer wheels, and roll bars wouldn’t be needed?
So are these dampers softer, equal to or stiffer than stock? Seems like there is always the debate of soft springs with stiff sway bars or stiff springs with soft sway bars, but not stiff n stiff or soft n soft. The idea of soft dampeners is to have a compliant ride and better vertical suspension travel with a stiff sway bar for reduced movement under lateral loads. How would you describe your setup?
Old 05-10-2020, 01:53 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
@Irace86.2.0 : check this thread.
Irace86.2.0 (05-10-2020)
Old 05-10-2020, 02:33 PM   #10
norcalpb
norcalpb's Avatar
If you think the stock rear bar (14mm) is compliant, you should check out the Mann Engineering rear bar. It is amazing on ultra rough canyon roads.
The Following User Says Thank You to norcalpb For This Useful Post:
Old 05-10-2020, 04:09 PM   #11
Irace86.2.0
Perfect off-road suspension.
Old 05-10-2020, 05:08 PM   #12
Racecomp Engineering
Dampers are generally not intended to control body roll.
I'm considering softer than stock front and rear bars for my car, but that's for gravel. It may make things a little worse on tarmac. Cusco has a 16mm front bar and a hollow 14mm rear (and there's the Mann bar).
Just for kicks...check out the landings in this video. Very different damper valving than what you see on a good road course set up!
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Capt Spaulding (05-10-2020), grumpysnapper (05-10-2020), Irace86.2.0 (05-10-2020)
Old 05-10-2020, 05:15 PM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
Irace86.2.0: dynamically adjustable suspension indeed is about perfect for performing it's function, no wonder active suspension was banned in F1 due providing great unfare advantage. But there are few "buts"/cons aswell. Especially so in light of use for common, daily driving applications. Not just cost/complexity, but also wear. One thing something overhauled between every race, another - which should last at least 20K miles, while not costing arm and leg. Be adjustment via air, hydraulic, turning knobs like in EDFC, or magnetorhelogical, or electromagnetic linear motors as in mentioned Bose system. All cost a lot, add complexity (thus things to potentially fail), and last less then "classic" dampers. Which, given high enough budget can perform rather well even without dynamic adjustment, if that budget is invested in quality & fine tuning or custom designing for a use. It might loose on some points while also win or not have some cons in other areas. And as dynamically proactively adjustable suspension is such a rare appearance, my hunch tells me that market has voted that on average as overall product/as compromise, pros are not that good and cons are serious enough.
@Racecomp Engineering: well, tarmac rally setup also is beast on it's own
Racecomp Engineering (05-11-2020)
Old 05-10-2020, 05:52 PM   #14
Irace86.2.0
I think it will trickle down. It is in use in the Audi S8 and other cars. With Lidar and other camera tech becoming mainstream, active suspension will eventually make it into cheaper cars just like active diffs, active suspension has worked its way down, just like ABS and other systems before them.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
WRX rear sway bar: good front sway bar combo? LerpK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2016 07:02 PM
FS: 2013 BRZ Premium - 6MT - Asking $17000 OBO Mageep Cars for Sale/Trade 9 03-18-2016 07:03 PM
2013 Asphalt FR-S 30,000 miles AT - $17000 Dreamshot Cars for Sale/Trade 3 11-17-2015 11:39 PM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 02:20 PM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 01:38 PM
