Drives: --
Coil Bind/Pillow Ball/Spherical Bearing Tein Flex A
Ill try to be brief. Sound is starting to drive me nuts.
I hear a creaking noise whenever I turn the steering wheel. It only occurs when either going really slow or at a standstill. Dont hear anything at speed. Sounds like the video below but not nearly as bad. [ame="https://www.youtube.com/watch?v=h3jLmpI-XAM"]Coilover Spring Binding - YouTube[/ame] Shop told me the spherical bearing in my front right coilover is seizing. Best way to fix is replace. They sprayed some lubricant on the top of the coilover which seemed to help a bit but a week later its back. Emailed Tein and they're refusing to send parts under warranty. Car has never been tracked, coilover usage is under 13k miles, and it's been 9 months since install. They're stating it MUST be sent to them because there is a "special tool" they use to remove the bearing from the mount. They're claiming I also have to pay for it because its wear and tear. Anyone replace the spherical bearing on a Tein Flex A? I saw others mention the radial bearing from Fortune Auto but dont know if its the same for the Teins. Any suggestions? PS, this is my first coilover but seems like bullshit to me that 9 months in its falling apart. I get wear and tear, but a coilover under 13k miles and under a year since install is ridiculous to me. I get they're not top of the line but I'm not tracking my car. Maybe you can tell me if I'm being unreasonable. Thanks Last edited by VOSS; 12-17-2019 at 01:57 AM. |
#2 |
Drives: 2014 GT86
First try tighten top nut maybe. Imho this vid might be helpful. Though also possible that bearing is already too worn (untightened simply propagates wear due play in it) and yes, needing replacement.
#3 |
Drives: Crapcan
I'd ask the shop how they came to the conclusion that it is seizing.
I'd also jack the car up and grab the spring and see if it rattles. The preload collar on my flex Z's would work loose and the spring would come loose. This would make it pop. |
#4 |
Drives: 2017 Toyota 86
Please let us know if you fixed it I was about to order a set but now.. I am not sure I want to fuck with the ride.
#5 |
Only users lose drugs.
Drives: All the time
It's 99% because of where you live, not necessarily the quality of the component, per se... You're in the snow belt, which means you're in the salt/sand/rust belt. Aftermarket stuff NEVER gets tested to the degree that OEM parts do for corrosion resistance, and this is the effect of using a brand that's on the lower end of the spectrum (TEIN can afford to be inexpensive not only because of the quality of components they use, but also their relative lack of service/support, which you're experiencing...repairs cost money), plus living in probably one of the worst locations on Earth for corrosion. I'm in New England, so I have the same problem; I've already had to replace my OEM strut bearings once and I'm only at ~65K miles. If you lived in SoCal or Arizona, you'd likely still be noise free...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following User Says Thank You to venturaII For This Useful Post: | CSG Mike (12-19-2019) |
#6 |
Spherical bearings can't be lubricated with a spray; they use solid dry lubricant.
If that spherical wasn't damaged before, your shop damaged it by spraying lubricant, and eliminated any possibility of warranty. It most likely wasnt damaged before, but is compromised now. That spring bind can be fixed with a fresh teflon washer/spacer, similar to the one that came with your coilover kit. The teflon is wear and tear, and wears out much quicker in Canadian conditions. You could use bearing based thrust washers instead, but those would wear out much faster. The washer is $6 each. Shipping it to you will cost more than the part. PM me if you want it. |
#7 | |
Drives: jrsc_brz
#8 | |
#9 | |
If the tops are articulating smooth without play, I'd say just run them as is and you'll be just fine. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | HaXx (12-19-2019) |
#10 |
Drives: Crapcan
I have been lubing my Flex Z's with spray white lithium grease for two years. No issues. That is not to say that in the future the lining won't be degraded, but so far so good.
| Tein Flex Z coil overs - SOLD | JohnnieBoy | Brakes, Suspension, Chassis | 4 | 11-20-2018 04:10 PM |
| D1 Spec Coil-Overs w/ Pillow Ball Mount (Toronto) | Sweet48 | Canada Classifieds | 7 | 11-19-2017 12:32 AM |
| Help needed with KW V3 coil overs and RSR pillow ball top mounts | RevoG | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 09-29-2015 10:17 AM |
| FS (GA) Tein Street Flex Coilover Adjustable w/ pillow ball mounts | GTHachiRoku | Brakes, Suspension, Chassis | 11 | 09-28-2014 11:09 PM |
| Tein flex pillow top coilovers | Frs89 | Brakes, Suspension, Chassis | 1 | 06-15-2014 07:37 PM |
