Old 09-05-2017, 11:35 AM   #1
Miguelgomez
Drives: 2016 FRS
Question
OK. So about 3 days ago i got a jump start the car sounded a bit off. I revved the car once (probably shouldn't have) and it sounded normal again but when i went to close the hood something made a banging noise. Since then when ever you accelerate or push in the gas it makes a whistle noise. Kind of like those turbo diesel trucks. Any idea of what it could be?
Miguelgomez is offline   Reply With Quote
Old 09-05-2017, 01:18 PM   #2
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
probably knocked a vac hose or something loose. try getting someone to sit in the car and rev while you listen under the hood.
unless this only happens when moving. that would be dangerous.
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 02:58 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 12:41 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
Oil question.. tintumz22 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 01-13-2013 01:41 PM
TCS/VSC question. Cheddar Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 09:29 PM
