Old 06-10-2016, 02:22 PM   #1
tskaohu
tskaohu's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWS
How to fix wheel poke
Just recently lowered my car on coils and my wheels and tires are so sucked in underneath my wheel wells and I don't like the look. What is the fix to add more wheel poke? Just bigger wheels and bigger tires? Or is there a step I'm missing.
1320 Performance Headers & Overpipe | HKS Hi-Power Spec-L Catback Exhaust | Delicious Tuning Flex Fuel Kit | Delicious Tuning Stage 2 Tune | Tein Flex A Coilovers | 20 & 25 MM Spacers
tskaohu is offline   Reply With Quote
Old 06-10-2016, 02:25 PM   #2
Tareim
Drives: 2013 Subaru BRZ
getting wheels with the right offset is how to do it
Tareim is offline   Reply With Quote
Old 06-10-2016, 02:38 PM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
'poke' is when they extend outside the fenders. you've got 'suck' lol.
cheap fix: wheel spacers. @Tareim recommended the right way. it's a combination of wheel width, offset and camber. tire size and cross sectional shape are also factors.
shiumai is offline   Reply With Quote
The Following 2 Users Say Thank You to shiumai For This Useful Post:
Summerwolf (06-10-2016), tskaohu (06-10-2016)
Old 06-10-2016, 02:53 PM   #4
tskaohu
tskaohu's Avatar
What's a good wheel size you would recommend for our car. I'm new to all this ahah
Sent from my SM-G935V using Tapatalk
Old 06-10-2016, 02:59 PM   #5
tskaohu
tskaohu's Avatar
At least something that will fix that 'suck' lmao
Old 06-10-2016, 03:03 PM   #6
swarb
3 options or a combination of the 3.
1. less camber
2. wider wheel/wider tire
3. less offset/wheel spacer
Look at the various wheel threads and find out what look you are going for and get a similar setup.
Old 06-10-2016, 03:07 PM   #7
gramicci101
Off Topic
What wheels do you currently have? What are your goals? You could run 18x9.5's with 265 tires all around, or you could run 17x7's and 215's all around. As long as the wheels have the right offset it will look flush to the fender.
Old 06-10-2016, 03:09 PM   #8
tskaohu
tskaohu's Avatar
I'm running the black sti rims that come with the series.blue brz. Pretty sure they are the exact same size as the oe rims. @gramicci101
Old 06-10-2016, 03:11 PM   #9
tskaohu
tskaohu's Avatar
I definetly want 18s and want the flush look. My look has definite suck right now. I want the tires to be flush with thefenders
Old 06-10-2016, 03:13 PM   #10
Nickosport
Drives: 2015 WRB BRZ Premium
Stock wheels need a 20mm spacer in the front and 25mm spacer in the back for a flush fit. Look in the wheel directory, there is a fitment guide that will tell you how different wheel size combos fit. There is also a database with pictures for a lot of wheel designs and sizes. Start with that.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
The Following User Says Thank You to Nickosport For This Useful Post:
86kahl (06-11-2016)
Old 06-10-2016, 03:17 PM   #11
gramicci101
Off Topic
Even saying 18 leaves a huge range. This thread, posts 2 and 3, has charts detailing how different sizes with different offsets fit the car, with links to examples.
http://www.ft86club.com/forums/showthread.php?t=7535
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
86kahl (06-11-2016), Leonardo (06-10-2016)
Old 06-10-2016, 03:58 PM   #12
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
use this. this is the bible for you
http://frsproject.com/
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
86kahl (06-11-2016)
Immobilizer - where is it? How can i poke at it? im_topher Engine, Exhaust, Transmission 8 11-10-2015 01:29 PM
What can I do about poke? Don't know what I'm doing rinnamon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 04-05-2015 10:38 PM
Pic Request: front wheel poke of 17x9 or 18x9 +35 on Prokit, TRD, RCE, or similar btoast Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-26-2015 03:38 AM
Poke's BRZ build Pokeguyjai Member's Car Journals 5 03-15-2014 12:10 PM
Help with poke on rear Ash.B Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-23-2013 08:19 AM
