| CANADA Canada |
Drives: 2014 BR"ZED" Sport-tech DGM MT
bedding in brake pads in GTA area
I just finished installing some StopTech Street Performance pads this afternoon and am looking for a few suggestions on where I could bedding it the pads in the DVP and 401 area
#3 |
#4 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
#5 |
Drive From Home
Drives: BRZ STI Performance
Just bed it on the 404 South to 401 East ramp when approaching the curve.
I've never had to bed in brake pads when new just use your brakes hard every now and then. |
#6 |
Drives: 2014 BRZ Sport-tech
Take it to a track
#7 |
( ͡° ͜ʖ ͡°)
| The Following User Says Thank You to drewbot For This Useful Post: | FLYFISHR (06-04-2016) |
#8 | |
I bedded in my HPS with stock tires on local streets. A few consecutive hard stops and you're good to go. |
| The Following User Says Thank You to infinity21 For This Useful Post: | FLYFISHR (06-04-2016) |
#9 |
I had thought trying to bed the pads in on any of the major highways with the cops around would have been just as successful as a limping deer being ignored by a pack of wolves. If I read Stop Tech info correctly I should be going from 100kph down to 15kph 8 to 10 times to built up the heat in the pads and rotors. I would have thought that doing that in front of anyone would be very annoying so I was hoping to find a quiet bit of road on which to di it.
| The Following User Says Thank You to FLYFISHR For This Useful Post: | Ahsila (06-04-2016) |
#10 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
I bedded my XP10s on the 407 at close to midnight. If you have high heat capacity pads, you cannot bed them safely on the DVP. That place is crawling with cars through all hours of the night.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
| The Following User Says Thank You to Frost For This Useful Post: | FLYFISHR (06-04-2016) |
#11 |
Drives: Subaru BRZ
In space where no one can hear you squeal! Seriously, I bedded brakes on highways by just taking the car to max speed limit and then braking hard and repeating the process.. obviously making sure there is no traffic behind or near my car.
| The Following User Says Thank You to JD001 For This Useful Post: | FLYFISHR (06-04-2016) |
#12 |
Like everyone was saying, find an open stretch of highway. You could try the 404 north of the Buttonville airport. Some off ramps work well too. Just make sure no one is behind you lol.
| The Following User Says Thank You to D_Thissen For This Useful Post: | FLYFISHR (06-04-2016) |
#13 |
Drive From Home
407 just watch out for the unmarked cop cars usually hiding behind big signs around Bathurst and Yonge stretch.
Safest off ramp with least amount of traffic is probably 401 East at Progress Ave Best Buy exit, you can go back out to 401 West via Brimley North and exiting at Kennedy to repeat the process. |
| The Following User Says Thank You to krayzie For This Useful Post: | FLYFISHR (06-04-2016) |
#14 |
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
I use industrial park that loops around at off hours, though i'm not sure if your area have any quiet ones.
Stoptech street pads should be fairly easy to bed in, if not regular driving will eventually do.
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC 15 WRX Sport - ISM 6spd - Ordered May 3, 2014 |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 06:17 PM |
| Newb Brake bed-in (bedding?) question | BigFatFlip | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-16-2016 04:40 AM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 02:45 PM |
| Squealing Tolerance Exceeded! Re-bedding Pads? | ShoShin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-13-2014 03:37 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
