Old 05-06-2014, 01:54 PM   #1
kh060
Drives: FR-s Ignition
The Cricket
Ok, now I am starting to get crickets every so often I drive my car. Sometimes I hear it and others I don't but I don't want it to get worse. I drive 90 miles daily 5 days a week to work so I am burning through my warranty and probably be out of warranty 1.5 years after I just bought it. I was going to have Toyota replace the part on my next free maintenance. I was just wondering if I were to get Toyota to replace the part under warranty now and when I drive pass 36,000 miles, same pump fails again, would it be out on my pocket?
kh060 is offline   Reply With Quote
Old 05-06-2014, 02:06 PM   #2
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
I'm guessing once warranty is over, it's over. Out of pocket unless they did a recall. But from what I read, there is no real fix for it yet.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
The Following User Says Thank You to LXXXV1 For This Useful Post:
CokeSlap (05-07-2014)
Old 05-06-2014, 02:11 PM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Tsbs are only covered under warranty (usually). However some manufacturers issue tsbs for customer satisfaction.
N1rve
Old 05-06-2014, 02:24 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
How has it failed?
Silly noises are annoying but odds are the next pump will make a similar noise. How many miles are on your car? Some people report the noise goes away over time.
Yes if you want to change fuel pumps after 36,000 miles odds are you will have to pay out of pocket unless you do some finagling.
ineedyourdiddly
Old 05-06-2014, 02:37 PM   #5
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
burning through the warranty? I haven't heard that the crickets have actually caused a pump to fail. The most common way to fix the cricket noise from my experience and from what I have read is to use a synthetic no ash 2 stroke oil and add it to the gasoline. Or you could add Lucas Upper Cylinder Lubricant like I do.
cjsporl1996 is offline   Reply With Quote
Old 05-06-2014, 02:53 PM   #6
Tromatic
Mine chirps, don't care. I've not seen one report of a failed pump, and they have "fixed" the pump four times by my count, and they still chirp. E-free gas or Uplon fuel lube seems to shut them up.
Old 05-06-2014, 02:58 PM   #7
kh060
Yes burning through warranty. Our cars are warrantied to 3 years or 36k miles I think. I bought the car October 19, 2013. The miles showing on the Odometer is at about 19,600. I am guessing the car wont make the 3 year mark considering I bought the car in October with only 12 miles on the Odometer.
I also bought a 2013 Avalon Hybrid on July 4, 2013 with 40 miles on the Odometer. I just did it's 25k oil change last week!
Old 05-06-2014, 02:59 PM   #8
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
went to get my free 15000 maintenance yesterday and service guy looked at my service history and told me there is a recall on the fuel pump and i should get it fixed.
have an appointment on thursday.
VuDism is offline   Reply With Quote
Old 05-06-2014, 03:03 PM   #9
kh060
Normally I don't care too, It's just that it started showing up on me and I know that my warranty is also coming to an end in probably a year or less even though I just bought it not even a year ago new.
Old 05-06-2014, 03:45 PM   #10
strat61caster
That's the bumper to bumper warranty that fixes minor things like noises, interior pieces failing early, lights etc.
If a fuel pump were to actually fail I believe it would fall under the 60k mile/5 year powertrain warranty:
Your engine, transmission/transaxle, drive system, seatbelts and airbags are covered for 60 months/60,000 miles (whichever comes first).
http://www.scion.com/cars/FR-S/warranty/
But as stated above, there have been zero fuel pump failures so far.
ineedyourdiddly
Pseud0logik (05-06-2014)
Old 05-06-2014, 04:27 PM   #11
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
Are either of these safe for the catalytic converter?
FlamingRectumSyndrome is offline   Reply With Quote
Old 05-06-2014, 05:17 PM   #12
cjsporl1996
the lucas product is safe. As for the 2 stroke oil, I would imagine even long term use of a synthetic ash-less 2 stroke oil would clog up the cat overtime.
Old 05-06-2014, 05:49 PM   #13
N1rve
N1rve's Avatar
RECALL!?
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
oaroyale (05-06-2014)
Old 05-06-2014, 07:08 PM   #14
Tromatic
Originally Posted by N1rve View Post
RECALL!?
TSB, a bit different.
CRICKET FIX! alex_86 Issues | Warranty | Recalls / TSB 142 12-04-2013 12:29 PM
Took my car to the dealership concerning the cricket noise. Ludacrits Issues | Warranty | Recalls / TSB 6 10-14-2013 04:18 AM
Chirping/Cricket Fix Out? deeranged Issues | Warranty | Recalls / TSB 15 10-02-2013 06:43 PM
Cricket TSB [deleted] Southern California 25 06-05-2013 07:01 PM
New trans, window, and cricket fix! foney_email Issues | Warranty | Recalls / TSB 11 03-14-2013 06:35 PM
