Old 04-03-2025, 12:39 PM   #1
StraightOuttaCanadaEh
Wes
Steering making squeaking/creaking/groaning sound
Relevant mods are Perrin Steering Lockdown, RCE Tarmac 2 coilovers and Verus top hats. This started fairly recently. I took it to the shop where they found that the coils were rubbing against the top hats. Steering limiter was put in but coming home it again started making the squeaking sound by the end of the drive. This makes me think the sound is coming from some part of the steering itself rather than suspension. Here are two videos, one from inside, one from outside. The steering wheel is being turned left and right in both videos. Would appreciate any pointers from anyone who had the same issue.
https://youtube.com/shorts/ej2xnxQln...shrBDEu5BCCQi_
https://youtube.com/shorts/goIqtASEd...1ynNa7Ko1VDeH4
Instagram: @gt86ws
Old 04-04-2025, 09:09 PM   #2
whataboutbob
AutoX-10/10ths every run
If you lift the front of the car off the ground, does it still do it?
Build thread:Here
Old 04-05-2025, 02:49 PM   #3
Wes
I only have a simple jack that lifts one side at a time unfortunately
Instagram: @gt86ws
Old 04-10-2025, 05:20 PM   #4
Wes
Bump. Anyone else?
Another thing I noticed is it only does this at the end of a drive. There was a post somewhere I saw where someone said a melting sway bar bushing was causing squeaking. Would make sense then that it's at the end of the drive when the exhaust components are hot.
Instagram: @gt86ws
Old 04-10-2025, 05:38 PM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Can your jack fit under the front of the car?
There is a jacking point where the radiator support is to lift from the front end.
Worth checking the bushings for peace of mind.
Old 04-11-2025, 12:53 PM   #6
Wes
Okay might try that! Thanks
Instagram: @gt86ws
Old 04-12-2025, 08:38 AM   #7
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Do a google search for electric steering wheel coupler and watch some videos and see if it is the same. I just did one on my 2012 Camry.
22R
22R is offline   Reply With Quote
The Following User Says Thank You to 22R For This Useful Post:
StraightOuttaCanadaEh (04-21-2025)
Old 04-21-2025, 04:05 PM   #8
Wes
I sprayed some wd40 into the top hats and up from the wheel well and the noise disappeared immediately. Having said that, wd40 is not really a lubricant and it didn't help for long. Also after reaching out to RCE it seems the Verus top hats don't have a lower radial bearing, which could be the cause of the issue. So I ordered some oem TRD top hats from Japan and will swap those in. TBC
Instagram: @gt86ws
Old 04-25-2025, 06:14 AM   #9
RToyo86
RToyo86's Avatar
RCE currently has limited supply of their lowering top hats that come with SuperStreet series coilovers. Might be worth a message depending how commited you are to TRD bits.
Old 04-26-2025, 05:36 PM   #10
Wes
Well the Tarmacs were made mostly for OEM top hats so I'm thinking that should be fine, plus honestly I kinda want the rubber top hats back lol. Had enough NVH
Instagram: @gt86ws
Old 05-05-2025, 02:25 PM   #11
Wes
Ended up being Racer X endlinks squeaking like crazy and the Verus camber plates not getting along with the Tarmac 2s. Went with TRD top hats from Japan and Moog endlinks that are regreasable
Instagram: @gt86ws
Steering Wheel Creaking Sound Swolzee Cosmetic Modification (Interior/Exterior/Lighting) 0 10-06-2022 11:17 PM
Groaning/Knocking Sound When Braking GrimeBot5k Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2021 04:20 AM
Groaning sound rosol16 Issues | Warranty | Recalls / TSB 17 02-23-2016 10:13 PM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
Groaning from Front End when Traction Lost Tt3Sheppard Issues | Warranty | Recalls / TSB 7 02-08-2014 05:35 PM
