Old 12-30-2012, 06:31 PM   #1
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Question Need V-belt tensioner torque value...
After installing my Crawford AOS, it looks like I may have inadvertently loosened the tensioner pulley bolt beyond factory spec. It's making a high-pitched whirrrr sound and I know that can't be good.
I've attempted to look it up in the FR-S manual but it appears that the web scraper had some authentication issues when it got to that page.
Any help would be greatly, greatly appreciated!
cobrabyte is offline   Reply With Quote
Old 12-31-2012, 11:18 AM   #2
cobrabyte
cobrabyte's Avatar
I ended up purchasing a subscription to Subaru's Tech Info site for 3 days. The v-belt tensioner is a self-contained unit and the manual does not carry torque values for that pulley.
I did, however, find the *real* culprit. It's one of the idler pulleys and I don't feel like pressing out the bearing. I ordered a replacement through Scion.
BTW, the torque value for idler pulleys: 26.6 ft-lbf.
The Following 3 Users Say Thank You to cobrabyte For This Useful Post:
exE36M3 (05-09-2015), scottryan (08-29-2020), Sportsguy83 (12-31-2012)
Old 10-10-2014, 11:47 AM   #3
Nephilim_Slayer_
I think i have the same problem. I'm at 40k miles and 25k of those are with the Vortech kit. I recently changed my crank pulley (perrin) and accessories (nst). I also put on a new belt. Everything was normal for about 3000 miles. Now I hear a whirling chirping sound that seems to be coming from a/c compressor. Its hard to tell because it only likes to do it under load. Typically 2500-5000 rpms. It also does this a lot more on decel. It has got progressively worse over the last two weeks. Seems to not do it nearly as much on colder days. It also seems to go away after the engine bay is heat soaked. I have noticed now that twice when I first turned my A/C on it blows a little bit of frost. It has never done this before. I live in Houston Tx.
Nephilim_Slayer_ is offline   Reply With Quote
pulley, tensioner, torque
No seat belt. Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 40 11-16-2012 09:07 PM
Seat and seat belt torque specs TheSt|G Scion FR-S / Toyota 86 GT86 General Forum 2 11-01-2012 10:52 PM
driver belt tensioner Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 3 07-10-2012 06:44 PM
Red Seat Belt - where to get? MarkMash Cosmetic Modification (Interior/Exterior/Lighting) 11 06-24-2012 12:55 PM
You wish you were this seat-belt! YukiHachiRoku Off-Topic Lounge [WARNING: NO POLITICS] 13 05-03-2012 08:43 PM
