Old 08-10-2014, 07:24 PM   #1
JM197
Drives: 2015 FR-S
Grinding noise during slalom
I know this isn't ideally the way you would treat a car, but I've noticed a loud grinding noise once when I was making sharp turning motions, i.e. slalom. The noise sounded like it was near the wheels, perhaps the wheels themselves. I was only going around 30mph.
The car is new, no mods.
JM197 is offline   Reply With Quote
Old 08-10-2014, 08:09 PM   #2
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Sounds like active handling
brz7400 is offline   Reply With Quote
Old 08-10-2014, 09:35 PM   #3
I'd suggest you check your car's tires pressures.
Most likely it's just the sound made by the tires on the road.
Old 08-10-2014, 10:07 PM   #4
nivek111070
Drives: 2014 GB Scoobie BRZ
mine makes strange noises while turning hard, I do believe it's my brakes.
nivek111070 is offline   Reply With Quote
Old 08-10-2014, 10:12 PM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
TC or LSD?
Old 08-11-2014, 10:16 AM   #6
radroach
Drives: car
Traction control noise.
Old 08-11-2014, 01:59 PM   #7
skuts?
skuts?'s Avatar
Drives: 2013 6spd Argento FRS/1995 BMW 325i
simple fix, hold traction control button for at least 3 seconds. Problem solved
skuts? is offline   Reply With Quote
Old 08-11-2014, 02:06 PM   #8
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
that just replaces the grinding noise with a screeching noise.
shiumai is offline   Reply With Quote
Old 08-11-2014, 11:28 PM   #9
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
TC tries to correct for skidding by using ABS to apply braking force. Try as suggested to drive in VSC Sport or TC Off.
zkv476 is offline   Reply With Quote
Old 08-11-2014, 11:50 PM   #10
whataboutbob
AutoX-10/10ths every run
Check your lug nuts. If they are loose it'll allow the rotor to shift on the hub and drag on your brakes. This will be especially evident when turning as there is a stronger lateral load on the wheel/tire.
Build thread:Here
Grinding in the 5th Hawk77FT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-21-2014 03:10 PM
Transmission Grinding Into 6th Mister Issues | Warranty | Recalls / TSB 13 11-12-2013 11:06 AM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 11:57 AM
Grinding from 5th to 6th tn08 Issues | Warranty | Recalls / TSB 3 08-08-2013 10:26 PM
