| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
How do I shift?
Drives: '13 GBS BRZ
Spacers on dual pattern wheels?
Bruh. I took 21 credits in math in College but I can't figure this shit out.
I want to run some spacers on my xxr 527 5x100/5x112 but I don't know how to make this work. What kind of spacers do I need? Or do I need adapters? Usually it's pretty simple when it's one thread pattern but with wheels like these, how do you solve this issue?
![]() Last edited by carsebuco; 09-01-2018 at 12:21 AM. |
#2 |
Drives: 2015 FR-S
Why not just a 5x100 spacer? You're not using a solar powered calculator at night, are you?
| The Following User Says Thank You to Impureclient For This Useful Post: | MrDinkleman (09-01-2018) |
#3 |
Country Boy 4 Life
What offset are your wheels? How much poke do you want?
5x100 hubcentric spacers with a hub bore 56.1 are what you want. Just figure out how thick.
I LIKE TIRES! |
#4 | |
How do I shift?
Drives: '13 GBS BRZ
+42 I don't mind a little poke, but I want at least 100% flush
#5 |
Drives: 2016 Oceanic, "base" model
#6 |
Country Boy 4 Life
How wide are your wheels?
I LIKE TIRES! |
#7 | |
TRACKBREAD
Get bolt-through spacers and get longer studs pressed in the hubs. |
#8 |
How do I shift?
Drives: '13 GBS BRZ
#9 |
Country Boy 4 Life
If you add a 20mm spacer, your wheels will poke like 9" +35 wheels. I have similar 18x8 +45 with a 1" spacer added. Im lowered 1" and have approx -1.4 front camber.
I'd get 20mm front and 25mm rear spacers. The wheels will have the same poke then. It will look great!
I LIKE TIRES! |
#10 | |
How do I shift?
Drives: '13 GBS BRZ
| The Following User Says Thank You to carsebuco For This Useful Post: | Leonardo (09-01-2018) |
#11 |
Country Boy 4 Life
I had 5mm extended studs, but then got bolt on spacers. I cut them to length. It is possible.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | carsebuco (09-01-2018) |
#12 |
How do I shift?
Drives: '13 GBS BRZ
Yep, definitely did not work without alterations. The oem stud sticks out just enough to hit back of the wheel, causing a gap where there shouldn't be one.
Now I can either: Cut oem studs Buy new, shorter studs Buy adapters (which for the cost isn't worth it) Buy new wheels altogether and sell mine. This might be worth it considering I'm not too sure about cutting up the studs
#13 |
Drives: 2005 Toyota Camry
... or just get longer wheel studs and open-ended lug nuts to use with your spacers.
If installing studs is too much work for what you want to do, just get new wheels. |
#14 |
Country Boy 4 Life
Is the issue just on the 20mm spacers or both?
I cut 10 studs in under an hour with a really dull old hacksaw. Cleaned up the tips with a file. I thread a nut onto the stud, cut it, unthread the nut which helps "clean up" the threads, and file the end carefully. Replacing the studs is not that complicated. I did my front ones in about an hour. The rear takes a bit longer. Spacers are a compromise for sure. Getting perfect width and offset wheels would be ideal. Sadly, the wheels I wanted only came in high (42 & 45) offsets. I have 5mm, 10mm, 12mm, and 25mm spacers to mess with.
I LIKE TIRES! |
| OEM STI wheels + Spacers | spicyricecake | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 07-14-2016 01:17 PM |
| Do spacers fit OEM Wheels ? | Wil | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 09-19-2015 11:33 PM |
| FS: OEM BRZ Wheels & 20/25mm Spacers | idanvan | Wheels and Tires | 13 | 09-05-2014 01:50 PM |
| Spacers on OEM wheels? | BRZlimited | BRZ First-Gen (2012+) — General Topics | 13 | 04-11-2014 08:47 PM |
| Stock Wheels Need Spacers? | theom | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-17-2013 12:49 PM |
