Old 01-13-2014, 02:23 AM   #1
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO)
Delicious Tuning breaks the 200 wheel horsepower on a completely stock Subaru BRZ (Scion FRS or Toyota 86), using only E85 fuel and EcuTeK ProECU RaceROM for custom tuning.
[ame="http://www.youtube.com/watch?v=AfgvtUIkRVE"]2013 Subaru BRZ Completely Stock 200+ WHP E85 EcuTeK ProECU - YouTube[/ame]
You heard correct a completely stock Subaru BRZ (Scion FRS, Toyota 86) with the following parts:
- stock headers
- stock front pipe
- stock over pipe
- stock exhaust
- stock intake
- stock engine
- stock transmission
- stock rims
- stock tires
- stock paper intake filter
- stock fuel rails
- stock fuel pump
- stock fuel injectors
Items used for breaking 200 wheel horsepower:
- EcuTeK ProECU
- E85 Fuel
- K&N Oil Filter
- Motul 8100 Oil
The car was run in 5th gear (closest to 1:1 drive ratios) on an AWD DynoJet Dyno. After only a few revisions to our original E85 tune (not 200+) we were able to dial on the 201 whp on an utterly stock vehicle.
* We also performance a 4th gear pull which netted us 197 wheel horsepower as seen in the dyno chart in the video.
Cheers,
William Knose
Last edited by DeliciousTuning; 01-19-2014 at 10:47 PM. Reason: forgot the oil and filter, fuel stuff
The Following 27 Users Say Thank You to DeliciousTuning For This Useful Post:
Black Tire (03-23-2014), Byebye (01-13-2014), Cal3000 (01-14-2014), cobrabyte (01-16-2014), Creole (04-02-2014), DAMotorsports (01-27-2014), dave77 (01-13-2014), DesertFrs (01-13-2014), ericmpena (01-25-2014), F1point4 (01-17-2014), fooddude (03-31-2014), jamesm (01-24-2014), jflogerzi (01-25-2014), JonnyJames (01-13-2014), MadFRS (01-13-2014), mikalem (01-13-2014), mkivsoopra (01-13-2014), Nasty Sausage (01-27-2014), Pacific (03-25-2014), solidONE (01-23-2014), Sportsguy83 (01-13-2014), suaveflooder (03-15-2014), TIE Pilot (01-13-2014), unvevo (04-07-2014), vynervt (01-13-2014), whataboutbob (01-13-2014), Wolfking (01-26-2014)
Old 01-13-2014, 02:36 AM   #2
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Wow, that's insane... Nicely done!
kayoh is offline   Reply With Quote
Old 01-13-2014, 02:37 AM   #3
nelsmar
Very nice! Keep up the good work guys!
My flickr - Canibeat
Local magazine scout
Old 01-13-2014, 02:57 AM   #4
JonnyJames
Drives: 2013 Whiteout FR-S
Niiiice!!! Definitely impressive!
Gotta say though... That oil filter doesn't look stock
JonnyJames is offline   Reply With Quote
Old 01-13-2014, 02:58 AM   #5
whataboutbob
AutoX-10/10ths every run
Nice way to break in your new car.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 01-13-2014, 03:05 AM   #6
DeliciousTuning
You caught me. You are correct I completely forgot to mention it does have a K&N oil filter and Motul 8100 oil. Which I am sure helps out a little bit.
Cheers.
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
Rod117 (03-25-2014), Sportsguy83 (01-13-2014), whataboutbob (01-13-2014)
Old 01-13-2014, 03:13 AM   #7
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Whoa. I had a feeling that people would figure out easier and easier ways to get more and cheaper power out of this car.
I wonder if you guys tried some bolt ons and if you could get some really sweet power numbers like 220whp?
dave77 is offline   Reply With Quote
Old 01-13-2014, 03:29 AM   #8
DeliciousTuning
Well one really cool mod on top of this E85 tune is an Airaid Cold Air Intake. We added it without removing the snorkel and picked up about 5 horsepower without changing the tune.
We then removed the cover as a test, similar to having no snorkel and picked up another 4 horsepower. So that should equate to about 210 whp without even touching the tune. Definitely like the fact I did not have to change anything with the Airaid Intake install. Just bolt on and go.
Cheers,
William Knose
Cross (01-17-2014), dave77 (01-13-2014), solidONE (01-23-2014)
Old 01-13-2014, 03:52 AM   #9
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Also, what was your baseline?, so we can know how much improvement there was. Thanks
Old 01-13-2014, 05:10 AM   #10
s2d4
s2d4's Avatar
What about the torque curve? AFR?
Baseline overlay?
Tune for peak hp?
How many runs did you do?
Is it consistent?
Can you overlay all the runs you did?
Anything else added? I know you said stock, but adding a bung for wideband is still stock?for full close loop?
The Following 2 Users Say Thank You to s2d4 For This Useful Post:
gonzo (04-02-2014), marcosowns (01-13-2014)
Old 01-13-2014, 05:21 AM   #11
s2d4
s2d4's Avatar
O, is this the tune he is running? Or has it been dialed back for daily use?
Also, what kind of E85? 91+ethanol? 100+ ethanol?
Old 01-13-2014, 09:31 AM   #12
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
i manage to get 192.5 whp with a performance exhaust and just some octane booster in the tank (added to 95 octane fuel), without touching the software...
Vladror is offline   Reply With Quote
Old 01-13-2014, 09:53 AM   #13
swift996
swift996's Avatar
Thanks for the honest disclosure of 5th gear.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 2 Users Say Thank You to swift996 For This Useful Post:
Nasty Sausage (01-27-2014), WithNolock (01-14-2014)
Old 01-13-2014, 09:56 AM   #14
Malt
Drives: 2015 WRX
I was under the impression that octane booster largely had such a minimal impact (around an increase of ~0.4 or less) that it was pointless and a complete waste of money. Also the additives in those things could potentially cause damage to O2 sensors or gaskets, not to mention the various environmental impacts of high MTBE content.
Malt is offline   Reply With Quote
EcuTek ProECU PI/DI Maps Added EcuTek Software Tuning 1 12-22-2013 11:23 AM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 01:01 PM
EcuTek ProECU Moto-East Tuned Group Buy! Xero-Limit Groupbuys 52 04-19-2013 01:58 PM
EcuTek ProECU twinturba Engine, Exhaust, Bolt-Ons 8 11-19-2012 08:28 PM
EcuTek's BRZ / FT86 / FR-S ProECU Software available for Pre-Order now Visconti Engine, Exhaust, Bolt-Ons 7 07-27-2012 02:00 PM
