Drives: Blue 2013 Scion FR-S
LOC vs. High Level Input and Wiring
So I finally decided to put an amp and sub in my FR-S and noticed after I took the stock HU out that it had no RCA.
After looking through the forums, I think I found the solution but I wanted to ask once more to make sure I'm doing it right. First of all, I bought a LOC for $20 but then realized my Boss M1100 Monoblock amp has stereo level inputs. So I'm wondering which would be better to tap into the speakers. My other question is am I correct to tap into the Signal wires in the rear factory amp's harness (pins 3,9,4, and 10 if memory serves right). Or should I tap into the Speaker wires (pins 1,5,2,6 I think)? I do plan on having a power line from the battery to the amp. Thanks in advance! |
#2 | |
Drives: 2017 Camaro 1SS
Either way should be fine, you're not going to notice it with just a sub. If you had a super hi-fi front end setup you'd definitely want to tap signal wires and not speaker level wires. If you do speaker level, use your LOC. If you do line level, use a hacked RCA cable. |
#3 | |
Drives: FR-S 10 #103 AT
The speaker wires are after processing in the amp to be fed to the base drivers. You want to tap the signal wires, which are theoretically unprocessed at that point. They are also speaker level, but not much power behind them. An external loc is generally not as clean as the hi level input circuitry built into an amp or active crossover, but especially not a $20.00 one. Return the LOC and go directly into the high level input of the amp from the car's signal wires.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#4 | |
Boosted Member
Drives: 2013 Subaru BRZ
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#5 |
Sweet. Thanks for the help.
I decided to just go through the speaker level inputs, however the harness that came with the amp for the speaker level input are 24 gauge wires which seem too small...plus there aren't any tap splices for wires that small. Went ahead and ordered the Metra harness for the factory amp (both male and female) to make a sort of extension area so I don't have to splice into the factory amp harness. |
| Clutch Input | dabocx | Forced Induction | 221 | 01-19-2016 07:20 PM |
| Level Up Garage BRZ | lookchris | Member's Car Journals | 14 | 11-25-2013 07:47 PM |
| My oil level was low! | FRSjeff | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 12-16-2012 12:22 AM |
| Another Level 86's | SportInjected | Great Lakes | 4 | 07-30-2012 11:13 PM |
