I love peanut butter
Drives: 2013 SWP BRZ Limited
Pro-Kit right height at each wheel
I recently installed pro-kit springs on my BRZ and last weekend put on 18" wheels. When I go around each wheel to check the drop, I can almost perfectly fit 2 fingers in all wheel-to-fender gaps except the drivers side rear--this wheel seems to be slightly lower. Does anyone else have this issue? The passenger side rear also seems a hair lower than the passenger side front.
#2 |
Drives: Subaru BRZ Limited
Best bet would be to take a measuring tape to it. I had the same issues with my Sportlines. My rear passenger side sat considerably lower than the rest of the car. Most Pro-Kits I've seen seem pretty even. Take a measuring tape and see exactly how much of a difference you're talking about here.
#3 |
Drives: GBS BRZ
Just throwing this out there. Did you make sure that the spring was sitting in the rubber piece the same way the old spring was. If it wasn't in that pocket where the spring ended I could see them initially sitting a bit higher making the others look lower.
#4 |
Yes, and I can't see 3 accidentally slipping out and only one staying in the right spot. If I had one higher than the three others then that could be possible.
| SEAT HEIGHT | ZOMFGAARON | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 01-06-2014 08:41 AM |
| Wheel gap - from suspension height or tire diameter? | CaptainSlow | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 01-27-2013 12:48 PM |
| car height problems? | industrial86 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 10-03-2012 07:43 PM |
| what height are you running | Im_SPEED | Tracking / Autocross / HPDE / Drifting | 0 | 09-27-2012 11:29 PM |
| BRZ/FR-S Trunk Height? | ngabdala | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-24-2012 01:41 PM |
