Old 04-01-2014, 12:24 AM   #1
Eg0
Drives: 2014 Scion FR-S AT - Asphalt
JDM 86 Airbag part number confusion
I'm in the process of ordering the 86 airbag from Japan but have found two different types.
I'm using SU003-03410 as the part number. The results are as follows (the number signs represent japanese characters that I can't decipher):
1 SU003-03410 ------------ 201203-201308 --------- ZN6
2 SU003-03410 ------------ 201308-(nothing) ----- ZN6 - B
The first column is obviously the part number. The second column (I'm assuming) is the model year. The third column (I'm assuming) is the trim/style. If my assumptions are correct, I should get the airbag #2 for the model year 201308 and trim/style zn6-b, correct? Or would it not make a difference?
Just trying to get the correct info before I spend $600+.
Also, sorry for the shitty formatting, couldn't figure out any other way to space it out.
Eg0 is offline   Reply With Quote
Old 04-01-2014, 01:46 PM   #2
DekaMori
DekaMori's Avatar
Drives: RWD
IIRC...there are two (2) different part#s for the airbags, as follows:
SU003-03410 - Single-stage airbag *will require swapping over the detanotor
SU003-03413 - Dual-stage airbag *direct-swap to our FR-S (USDM), since we also use dual-stage
**I know this doesn't exactly answer your question, but thought I should throw the info out there too.
DekaMori is offline   Reply With Quote
The Following User Says Thank You to DekaMori For This Useful Post:
ProjectGT86 (04-01-2014)
Old 04-01-2014, 04:33 PM   #3
Eg0
I'm aware of that but there are two different ones for SU003-03410 as well. There's a Japan-spec one and a euro/overseas one as well.
Thanks anyway
I guess as long as I'm switching the detonator it shouldn't matter which one I get, right?
Old 04-01-2014, 06:39 PM   #4
kbye
kbye's Avatar
Drives: 2014 FR-S
You don't need to swap the detonator if you get SU003-03413, that is the point @DekaMori is trying to make.
Save yourself the trouble and get the dual-stage because they cost the same and look the same anyway.
kbye is offline   Reply With Quote
The Following User Says Thank You to kbye For This Useful Post:
DekaMori (04-01-2014)
Old 04-01-2014, 06:54 PM   #5
Eg0
I understand but the only one that I was able to find was the SU003-03410.
Old 04-01-2014, 07:01 PM   #6
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
where are you ordering these from?? Where can i order the dual stage one
ProjectGT86 is offline   Reply With Quote
Old 04-01-2014, 07:03 PM   #7
Eg0
I'm in Japan so I'm ordering from a local shop, I'm not sure where you can find the dual stage
Old 04-01-2014, 07:05 PM   #8
ProjectGT86
do you know where i can order the dual stage one
Old 04-01-2014, 07:06 PM   #9
kbye
kbye's Avatar
Drives: 2014 FR-S
Ah, ok gotcha. The two parts should be identical, but I agree that you should get #2 since it falls within your model year, just to be safe.
Old 04-02-2014, 12:17 PM   #10
DekaMori
DekaMori's Avatar
Drives: RWD
Sorry, not sure...probably need to source from outside JP, as item was intended for export models.
@Eg0 - if you're in jp right now, perhaps may want to check out/swing by upgarage to see if they have any laying around and swap your detonator when you get back state-side
Old 04-02-2014, 06:05 PM   #11
Eg0
@DekaMori
I wasn't able to find any dual-stage. I'm going to go ahead and order the single stage and swap it out when I'm back. Thanks for your help.
The Following User Says Thank You to Eg0 For This Useful Post:
DekaMori (04-03-2014)
Part Number help Sh944 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2013 02:10 PM
what's the part number for this? chenshuo BRZ First-Gen (2012+) — General Topics 11 10-07-2013 11:22 AM
need a part number the Red Devil Scion FR-S / Toyota 86 GT86 General Forum 0 12-12-2012 12:42 PM
I need a part number Bones36 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-01-2012 05:25 PM
Part Number for this DriftEightSix AUSTRALIA 20 06-25-2012 08:30 PM
