| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
I need help choosing rims...
Looking for suggestions on what rim would be a good choice for me. I've been looking for a while and I still cant put my finger on exactly what I want to go with. I do have some specifics nailed down though:
They need to be OEM size since I already have PSS tires to put on them, I also factory suspension. I do plan on autoX and PDXing the car often, but just for fun. I have a budget of about $700 dollars, $750 tops. Any and all suggestions to look into would be much appreciated! Oh yeah, they will be going on an asphalt FR-S. |
#2 |
I personally really like Rota titans. Inexpensive and fairly lightweight. 17 x8 weigh 17lbs. And they are in your price range. 17x9 's are 17.8 lbs.
| The Following 2 Users Say Thank You to FunCon5 For This Useful Post: | fstlane (02-27-2014), IAmNotTheDriftKing (02-28-2014) |
#3 |
Drives: Scion FR-S
Go on Nasioc forum and try to find a set local. I got my set for $700 (Older set of SSR Type Cs).
Same hubcentric size and lug pattern as our cars. |
#4 | |
Driving Enthusiast
Drives: 2013 BRZ Limited
Do you live in a pot hole free area? Anyone can correct me if im wrong.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.My BRZ |
#5 |
Drives: I own an FR-S. . . whatelse!
If you are staying OEM size you can get some Enkeis for around that price. You can probably get some used Rays as well. If you want to go all out and go with 17x9s you can get Rota Titans for about 700 bucks.
#6 | |
Time Traveller
Is it construction method? Are all non-forged wheels knock-offs? Original design? How did you determine what mfg had the "original"? Original style? How did you determine what wheel was the "original"? Lastly what about the stock wheels, are they knock offs? Many people autoX and track on them and they hold up great. What criteria above make them better than "knock-offs"? |
| The Following User Says Thank You to DAEMANO For This Useful Post: | SirBrass (02-28-2014) |
#7 | |
Driving Enthusiast
Like I said I'm not an expert just in other threads ppl have classified rota as knockoffs and fragile. Idk what though. Sent from my iPhone using Tapatalk
#8 |
Thank you guys, Ive been looking a lot and I think I did actually find the set for me. lol, its funny because they look A LOT like the stock rims which I like so much, but even a little better AND a little lighter :o)
![]() What do you think? |
#9 |
Rota Titans. Don't let people tell you Rota are bad quality. They are 1 piece cast wheels. Looks good and they are about 3LBS lighter then stock.
| The Following 5 Users Say Thank You to jflogerzi For This Useful Post: | barabia (02-28-2014), IAmNotTheDriftKing (02-28-2014), SirBrass (02-28-2014), SkAsphalt (02-28-2014), suaveflooder (02-28-2014) |
#10 |
Rota's have come a long way from the "old days" Don't let the "knock off" idea scare you off. The difference between rotas and "real wheels" is usually whether they will crack or bend. Good news, is that if you crack a rota, you still have a spare tire
Also, it's going to take a lot to crack one. The pot hole idea is a little bit of an exaggeration…..unless it is a BIG pot hole.
#11 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Enkei Fujins are in your budget, and are lighter with better fitment than the T-Forks (+40mm offset 17x7.5 wheel weighing 17.1 lbs versus a +45mm offset 17x7 wheel weighing 18.2 lbs)...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
| The Following User Says Thank You to Vracer111 For This Useful Post: | barabia (02-28-2014) |
#12 |
Ok, so I checked out the titans and theyre not bad. I like them in both black and hyper black, but I dont think they will work with my tires? (PSS, 215 wide) Also, the fujins are a model that I was considering for a while and theyre not bad either but they just dont do it for me :o/ same thing with the RPF1, I mean obviously yes they are a really good choice and TONS of people are using them but for whatever reason I just dont care for the looks of them. I guess Im like 60% form 40% function on this. Im still really digging those T-forks, almost certain thats exactly what Im looking for. I do appriecate all of your help and sugguestions, and Id like to hear some more if anybody has any.
#13 | |
As far as I can tell, and correct me if Im wrong because I very well could be, the factory rims are 17x7 48mm offset. So if I go with 17x7 45mm offset, that is only 3mm away from factory, and its actually 3mm wider than factory, so thats a good thing, right? Or if anything a nearly inconsequential thing. If the 215 tires do fit on 7.5 wide rims and the offset is 40mm, wouldnt that make it 8mm wider than factory? Possibly creating the 'poke' stance that people (myself included) want to avoid? Im trying to learn and 'see' as much as I can using the fitment calculator in the sticky but as good of a tool as that is I just need more practical insight, I suppose. |
#14 |
Alright, so it seems you want to get a nicer set of wheels but without having to worry about rubbing. Well, you won't have to worry about rubbing unless you get some much much wider wheels. You can run a 17x9 with a 42mm offset with zero issues on OEM suspension. If you are sticking with a 17x7 wheel, you have no issues what so ever with fitment. Even if you decide to go a bit wider at 17x8, you won't have to worry.
| The Following User Says Thank You to IAmNotTheDriftKing For This Useful Post: | barabia (02-28-2014) |
| Help needed in choosing color rims for RED FR-S | ciotime | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 33 | 07-12-2016 04:01 PM |
| Help choosing rims | psyclone07 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 02-10-2014 11:21 PM |
| Need help choosing kit | DannyFRS | Forced Induction | 16 | 11-15-2013 02:49 PM |
| Help needed in choosing color for FR-S rims | ciotime | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-09-2013 10:12 PM |
| Need help choosing... | ap5512 | Other Vehicles & General Automotive Discussions | 23 | 09-18-2012 06:24 PM |
