| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: BRZ 2014 SWP
245/40/18 Stock Susp. Will I rub?
Anyone know? Will I have to roll my rear fenders?
#2 |
Drives: FR-S Whiteout
Depends on the offset. With 45mm you should barely clear with slight chance of rubbing the springs with the wheels turned, if you did not add any negative camber. 40mm with 2.6* of camber will rub slightly, from my experience.
#3 |
Drives: Frs
I ran(on pothole infested LA streets) 255 40 offset 18s for a week before installing my kw no rubbing...
#4 | |
Time Traveller
Especially in the front. The rears will clear with no problem. In the front offset is just about everything with this tire widths 245+ in size, especially on 9" wheels. You're shooting for 45-35 offset with 9" wide wheels on 245-255. Make sure to have a pair 3mm hubcentric spacers handy just in case you rub due to the difference in tire width from one mfg to another. Once again this is specifically in the front. The rears will clear no problem. |
#5 |
Drives: SWP 86 GTS 6MT
Why not go 245/35/18? Rolling diameter remains the same as stock and absolutely no rubbing
| Fr Susp noise on gravel or bad pavement. | Ozzman | Issues | Warranty | Recalls / TSB | 17 | 11-03-2015 07:29 AM |
| TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar | BumpersFRS | Exterior Parts (Aero, Lighting, Etc.) | 1 | 01-11-2014 04:42 AM |
| WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses | Sony | Engine, Exhaust, Bolt-Ons | 0 | 11-21-2012 12:10 AM |
| FS: Ecutek Cable, stock axleback exhaust, stock springs | Philly | Canada Classifieds | 4 | 11-02-2012 09:50 PM |
| Whiteout Project Underway-Five Axis Kit Cusco Susp with TSW Wheels | Norcalscionchamp | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 08-19-2012 09:33 AM |
