Old 02-05-2013, 09:46 AM   #1
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Full Blown Stage 1 Short Block
We've been building quite a few short block for the FA20 Engine. Our blocks uses nothing but the best parts to ensure that it will endure the abuse. We keep a couple of cores and plenty of pistons and rods in stock to minimize the wait times.
This is the same block found in our 700HP Shop Car. Although this is a fairly new platform, We have learned how to keep these engines together with the right parts and clearances.
Please contact us for your shortblock builds.
FBM FA20 Short Block
- Full Blown 1000HP Connecting Rods
- Full Blown Spec 1000hp Arias HD Pistons 9.5:1 or 9:1 Compression with upgraded Wrist Pins
- OEM Bearings
- Fully Balanced and Blueprinted
Price: $3095
FullBlown is offline   Reply With Quote
The Following 19 Users Say Thank You to FullBlown For This Useful Post:
cmss2000 (02-05-2013), Dadhawk (02-05-2013), Dinko (12-17-2013), Dipstik-sportech (08-31-2013), GhostOp86 (11-26-2016), Guff (02-06-2013), Hardrock4445 (02-05-2013), Jeff86 (02-09-2013), killerkid08 (09-01-2013), Kochinopride (02-05-2013), Lawnik (02-05-2013), n2oinferno (02-05-2013), OjiGeorge (03-09-2014), Pure Automotive (02-05-2013), shiro (09-01-2013), SnapOv3st3r (02-05-2013), Sportsguy83 (02-05-2013), Tansey86 (02-05-2013), TyperRspec789 (02-05-2013)
Old 02-05-2013, 11:00 AM   #2
OrbitalEllipses
Drives: Attitude
Low compression turbo engine?
Old 02-05-2013, 11:05 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yep. Should be able to run quite a bit more boost with 93 octane and those pistons.
Old 02-05-2013, 12:05 PM   #4
Cheddar
Saving them pennies...
Easily 400-450whp on pump with that bottom end........I guess it would be considered a center end on a boxer........but it doesnt end anything.....F it! Short block! lol
Cheddar is offline   Reply With Quote
The Following 3 Users Say Thank You to Cheddar For This Useful Post:
Calum (02-12-2013), Kiske (03-31-2014), nix (02-07-2013)
Old 02-05-2013, 12:13 PM   #5
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Even though those wall look beefy, the fact that its an open deck still might pose a threat. Im sure if they thought so they would tell us. Im sure this thing could handle 5-600hp all day no problem.
Tansey86 is offline   Reply With Quote
Old 02-05-2013, 12:32 PM   #6
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
@FullBlown.
Glad to hear that your stock block is still holding up. You guys were pushing it pretty hard and I was getting curious about it.
Do you have any thoughts on the biggest weak point of the stock short block yet or where the most likely failure area may be under boost?
Scott
naikaidriver is offline   Reply With Quote
The Following User Says Thank You to naikaidriver For This Useful Post:
Pete (02-05-2013)
Old 02-05-2013, 12:37 PM   #7
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Has most of the abuse on the stock block at the higher power levels been under load?
tech4pdx is offline   Reply With Quote
Old 02-05-2013, 02:20 PM   #8
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
I wonder if you guys can build me a block and all the trimmings to run up to 1,000HP and safely drive it every day
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3
2013 Scion FR-S
2011 Land Rover LR4
2013 Lamborghini Gallardo LP570-4 Superleggera
Kochinopride is offline   Reply With Quote
Old 02-05-2013, 02:47 PM   #9
Orthow
Drives: 99' SIR Kswapped Racer/Showcar
Judging solely on your automotive laundry list in your signature I'd say you would be a perfect candidate to have a 1000hp block put together. The ONLY potential limitation in the build would be the clients cheque book but it's clear that would not be much of a concern for yourself!
Orthow is offline   Reply With Quote
The Following 2 Users Say Thank You to Orthow For This Useful Post:
Kochinopride (02-05-2013), Murseman27 (02-08-2013)
Old 02-05-2013, 03:25 PM   #10
nonicname
Drives: it has 4 wheels and a motor
why wouldn't you just drop low compression pistons instead of having to built a block as a project?
nonicname is offline   Reply With Quote
Old 02-05-2013, 03:33 PM   #11
bakerr6
Drives: 2013 raven black fr-s
I'd be interested in this in a couple years. TBH, I'ms till trying to learn how to effectively drive this thing at lower power levels. I've never owned a car this slow that's this much fun (I've owned plenty of other cars between 400-600 rwhp and tq)
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
Jeff86 (02-09-2013)
Old 02-05-2013, 04:28 PM   #12
Sargy
Long Distance Driver
Sargy's Avatar
Those Cylinder walls.... beautiful piece.
Sargy is offline   Reply With Quote
Old 02-05-2013, 05:50 PM   #13
dabocx
dabocx's Avatar
Drives: Scion FRS
Head work coming soon?
dabocx is offline   Reply With Quote
Old 02-05-2013, 05:55 PM   #14
Tansey86
Tansey86's Avatar
These heads are a work of art, I doubt you'd ever have to touch them.
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
Initial Review + First Dyno Run for my Full Blown Turbo FRS on Friday, Feb 1 @ 3pm TyperRspec789 Mid-Atlantic 66 02-02-2013 02:25 PM
