Old 03-30-2014, 05:07 PM   #1
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Do any short shifters improve the downshift to 2nd?
One thing I don't like about the transmission is the downshift to 2nd is pretty awkward, and it's hard to do smoothly and quickly. Wondering if a short shifter would improve that. Like kartboy or something. I know ofc that it would shorten the throw by x%, not not sure about that clunky awkwardness down to 2nd.
dave77 is offline   Reply With Quote
Old 03-30-2014, 05:17 PM   #2
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Not sure about a short shifter, but these are supposed to make a big improvement to the whole shift action:
http://www.ft86club.com/forums/showthread.php?p=1334277
I have a set on order
Pitman is offline   Reply With Quote
Old 03-30-2014, 05:17 PM   #3
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I couldn't agree with you more. Down shifting into 2nd is not as easy as I would like it to be.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 03-30-2014, 06:54 PM   #4
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Originally Posted by Monogram View Post
I do not have any issues downshifting into 2nd even when the trans is cold. Double-clutch or heal-toe double-clutch.
Yea it's not too bad, but (maybe you have) comparing to other transmissions in other cars, it's not quite as good, and room for improvement. My 2006 STI was way better in this regard. It's weird how you can't really downshift into 2nd in a smooth motion, b/c you have to shift to the left pretty far in neutral position to then go down to 2nd.
Old 03-30-2014, 06:56 PM   #5
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
I assume you don't actually double clutch, that was necessary on older cars when transmission wasn't synchronized or whatever. Now you only have to do single clutch.
Old 03-30-2014, 07:06 PM   #6
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Thanks man! Definitely the type of thing I'm looking for...
Old 03-30-2014, 07:50 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
What cars have you driven before? The 86 has the shortest throw g/box of any car I have driven. When you down shift to 2nd what is happening? Are you moving the stick to the wrong spot or are the synchros bulking and making it slower to shift into?
1974 TA22 Celica
2013 86 GT
Old 03-30-2014, 08:12 PM   #8
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
It's like I described. It seems like the move over to the left to get into 2nd from neutral is far, so that when going down from 3rd I gotta make it 2 conscious movements down to neutral and then into 2nd. It's like 2nd gear is too far to the left.
Old 03-30-2014, 08:27 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
I would say that is just something you will get used to. But if it erks you a short shifter will fix that. Everyone has their own preferences with that sort of thing. Personally I would prefer a shorter clutch throw than the shorter shift.
1974 TA22 Celica
2013 86 GT
Old 03-30-2014, 10:06 PM   #10
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
I've driven for 7,000miles, so ya know I kinda know what I want to change now. A short shifter and those springs mentioned above sounds like a great combo.
FYI you can adjust the clutch pedal down. It's really easy once you get used to being upside down under the steering wheel. Just gotta make sure to test it out so that you didn't adjust too low.
http://www.ft86club.com/forums/showt...dal+adjustment
Old 03-30-2014, 10:11 PM   #11
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
I noticed when I installed my weighted shift knob, shifting to the corner gears seemed to be a bit smoother.
Ny Brz is offline   Reply With Quote
Old 03-30-2014, 10:19 PM   #12
gramicci101
Off Topic
So you're saying he was double clutching, not granny shifting like he should?
Old 03-30-2014, 11:25 PM   #13
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
It doesn't matter if you win by an inch or a mile, winning's winning.
Old 03-31-2014, 01:19 PM   #14
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
As I stated before, I do not have any issues at all shifting this transmission, and I find it very user friendly. It had been a number of years since I had owned a manual trans vehicle, and there was no learning curve ... other than reverse.
Unless I am rolling to a stop, I always double-clutch down. Is it necessary in a modern syncro'd transmission? I'd say yes.
Yea, but we're simply talking here about the DOWNSHIFT INTO 2nd GEAR FROM 3RD GEAR. Since it's been in while that you've driven a manual, you prob don't have many cars to compare it to.
>>>Rev Works - Clutches - Drive Shafts - Short Shifters -All Your Drivetrain Needs<<< Rev Works Transmission and Driveline 210 09-12-2014 03:45 PM
Short Shifters! Pro Billet vs. Kartboy xDanger_208x Engine, Exhaust, Transmission 9 03-06-2014 09:32 AM
1 Way To Really Improve Your Driving CSG Mike Tracking / Autocross / HPDE / Drifting 5 01-22-2014 10:43 PM
◘◘◘ Billet Pro Shop Short Shifters ◘◘◘ with colored lock outs - In Stock! FT-86 SpeedFactory Transmission and Driveline 18 11-18-2013 10:44 PM
Looking for feedback and thoughts on Kartboy and TWM short shifters for our cars OICU812 Engine, Exhaust, Transmission 2 07-25-2013 05:02 PM
