Drives: Firestorm FR-S MT
Hard start, take it to dealer?
I know pitifully little about the inner workings of the ignition system, help me!
I live in Utah and it's starting to get warmer (mid 80s, summers reach 100). I'm hoping this is an isolated coincidence, but for two days in a row I've had slow starts after work. Have to hold it for a good 3 seconds before the engine grumbles to life. Doesn't seem like battery, I can hear the spark plugs firing (if that's actually what you hear when you start a car). Is it pure coincidence that it has worked fine in the morning but not in the afternoon, or would any of you smart cookies know if/why the heat should affect it? And most importantly, should I urgently be taking it to the dealer instead of calmly asking you guys?
#2 |
Keep Calm And Drift On~
Drives: Scion FR-S WhiteOut 6 Speed Manual
lets try this NOM, when you turn the key to Accessory on(just before you crank the motor) allow the fuel pump to run (should only last 5-8 sec) this primes the fuel system for cranking.
what you are hearing is a mixture of 8 injectors , 4 spark plugs and a starter (among other things) working together to get that puppy going! good luck |
| The Following User Says Thank You to Wo6M For This Useful Post: | strat61caster (05-21-2013) |
#3 |
Drives: '13 FRS - STX
If the above post doesn't "fix" it then take it to a dealer, there's something not functioning properly.
There's been a couple threads on this, I think 98% of the time it's just people turning the key all the way to "start" without allowing the car to wake up and prime itself. |
| The Following User Says Thank You to strat61caster For This Useful Post: | CamryDS (05-22-2013) |
#4 |
My car did this to me too at lunch(12 pm).
It was in the high 70's if hat makes a difference but it took me 3 try's before it turned over.. |
#5 |
Drives: 2020 GMC Canyon Denali Diesel
Take it to the dealer, there are two potential fixes available depending on what the dealer actually finds as the cause of your starting issue; 1) ECM Reflash, 2) Crank Sensor Shim. Either one should take less than an hour to do.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#6 |
Drives: Attitude
Had my first hard start since March a few days ago, but it's entirely inconsistent when it occurs. It was a really rough start, instead of trying to crank it sounded like the engine turned over then nearly died then came back to life. Pretty sure if I went to the dealer they wouldn't be able to reproduce it.
#7 |
NASA SpecE30 Racer
Unless you can consistently reproduce it, I wouldn't take it to the dealer. Is your car 100% stock OP?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Conor (05-22-2013) |
#8 |
yessir
I'll try priming it first and report back, thank you for the suggestion! |
#9 | ||
Drives: '93 Toyota MR2 - V6
If it's turning over like normal and is taking extended cranking to start, it could be fuel-related, like fuel pressure is bleeding off after the car sits all day. Has the car ever done this after only sitting for 10-15 minutes, like if you went to the store and got back in to drive home fairly quickly? Quote:
| Hard start ?? | Rayme | Issues | Warranty | Recalls / TSB | 44 | 03-28-2015 09:51 AM |
| Need new bumper, but dealer said paint is hard to match | midnitz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 59 | 04-05-2014 05:16 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 03:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
| We should start a dealer BRZ order database | eikond | BRZ First-Gen (2012+) — General Topics | 13 | 03-01-2012 01:56 PM |
