Coilover Spring Length
For those of you putting together your own coil overs, what spring lengths have you used? I'm currently looking for 2.25" diameter used linear rate springs for testing on my MCS dampers, and have only found a couple of published coilover spring lengths that seem to vary from ~ 5.5" to 7" front and ~ 6.5 to 7" rear.
What length has everyone gone with? I'd prefer to stay as short as possible, but don't want to go too short. Anyone have off the shelf setups like Ground Control, KW etc. that they could measure spring lengths for me? Thanks, Joe |
#2 |
You could PM GTB/ZR-1 he has the MCS shocks. Here is a picture of one of his installed coilovers, he is using 7" Eibach springs (the 0700 is the length). I think the MCS shocks are the same length front and rear so he's probably running 7" on both ends. He's about in the middle of the shock so it looks like about the right length you'd want to use, but you could probably go 6" and be fine as well.
http://farm9.staticflickr.com/8529/8...bc81aae0_c.jpg |
#3 |
Drives: On track
Joe,
Id say a lot depends on the shock casing length and shaft length - i.e. a lot of information here may not be relevant unless they have your exact same setup. It also depends on what ride height you want to run and if you're going to be running tenders/helpers, or have coilovers that are independently height adjustible from spring preload. Have you tried contacting MCS or any other members (I can think of one that is already running the MCS stuff) for their input? Best of luck! Austin |
#4 | |
Have spoken with MCS, and they haven't sold enough stuff for the twins to be 100% sure. I would like to be able to adjust between no drop and 2" while I test and tune and figure out spring rates. I'll attach a pic of my shocks here. As you can see, the rears have a much larger threaded area, and should be easy to pick a spring length for. I'm trying to keep the springs as short as possible to minimize weight. I've decided on 7" for the rear, from the GTB/ZR-1 pic. I'm probably going with 6" for the front. The threaded area being shorter, I don't want to go too long and miss it and not be able to lower the car. I can always add a helper spring setup later if I'm a bit too short. I don't think that the 6" will go into coil bind with the amount of shock travel that we have in the front.
#5 |
Drives: DC5
very nice! LOL how do they not know? Have them send you a bunch of springs to test out.
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 07:30 AM |
| To coilover or spring? That is the question... | Knightmare | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 01-13-2013 11:34 PM |
| Rod length | F3dzo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 12-27-2012 02:24 AM |
| Kronos Coilover/Spring MEGA THREAD! Special Prices inside! | KronosPerformance | Brakes, Suspension, Chassis | 46 | 09-09-2012 09:22 PM |
