Old 04-26-2013, 09:10 PM   #1
2thdoc
2thdoc's Avatar
Drives: Scion FR-S
Exterior temperature
How do I change the temp from Celsius to fahrenheit?
2thdoc is offline   Reply With Quote
Old 04-26-2013, 09:41 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
1.Determine the temperature in Fahrenheit(look at dash readout)
2.Using your calculator, subtract 32
3.Multiply the result times 5
4.Divide that answer by 9
5.Your final answer is the temperature in Celsius
Jkjk, bump for answer!
The Following User Says Thank You to continuecrushing For This Useful Post:
Anthony (08-30-2013)
Old 04-26-2013, 10:50 PM   #3
fistpoint
Drives: Supercharged Golf Cart
I thought you guys shun our systems down here, why would you want "F" instead of "C"? I figured your cars would have already been setup with "C" anyway.
fistpoint is offline   Reply With Quote
Old 04-27-2013, 12:09 AM   #4
kALMIGHTY
Drives: TRD Ultramarine '13
...Umm he wants Fahrenheit, not Celsius.
With that said, I have no idea. Lol.
Old 04-27-2013, 12:10 AM   #5
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
You'd think if you change it from MPH to KPH it would change the temperature from F to C respectively. Go figure.
Mandy is offline   Reply With Quote
Old 04-27-2013, 06:36 PM   #6
continuecrushing
Wow...I fail at reading lol.
Anymore info from someone to change it?
Old 04-27-2013, 08:49 PM   #7
2thdoc
2thdoc's Avatar
Drives: Scion FR-S
I've tried that and it does nothing. I want the temp in F not C.
Old 04-27-2013, 08:54 PM   #8
2thdoc
2thdoc's Avatar
Drives: Scion FR-S
I live right across the river from Detroit michigan. I've grown up watching American tv and I prefer F over C. The car is set to C because I bought it in Canada.
Old 04-28-2013, 04:32 AM   #9
fistpoint
I apparently reversed my reading skills halfway through my response.
Old 04-28-2013, 02:15 PM   #10
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
Anyone else notice anything weird with their temp sensor? Mine was reading 100F the other day when it was about 81 outside. I started the car and it ran like crap for about 5 minutes before it straightened out a bit and the temp was reading correctly. Its only happened once so far.
Freetime is offline   Reply With Quote
Old 04-28-2013, 03:28 PM   #11
FRyeS
Drives: 2013 FR-S Asphalt 6MT
Pretty sure that when the car is sitting (in the sun for instance) you're not going to get an accurate outside temp reading.
Also pretty sure the thermometer reading has zero to do with how your car is running.
FRyeS is offline   Reply With Quote
The Following User Says Thank You to FRyeS For This Useful Post:
davesrave (04-28-2013)
Old 04-28-2013, 03:33 PM   #12
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Subtract 32, divide by 1.8 = °F to °C
Multiply by 1.8, add 32 = °C to °F
Less steps
Sellout is offline   Reply With Quote
Old 04-28-2013, 03:34 PM   #13
Hardrock4445
Hardrock4445's Avatar
can dealer switch over in ECM settings with factory scan tool? i know settings like DRL on/off and lock/unlock can be switched from beep to horn.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 04-28-2013, 03:55 PM   #14
Freetime
Freetime's Avatar
I realized that the thermometer had nothing to do with the car's performance. I just noticed the two at the same time. Maybe the black car just got that hot out in the FL sun and it didn't like it? Not sure. Hasn't happened since though. We haven't yet made it to the really hot summer months here though.
Guess I am going to start walking a bit further just so I can park in the work garage.
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 09:55 AM
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 11:05 AM
BRZ temperature display malfunction percyng CANADA 7 10-24-2012 10:31 PM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 11:33 PM
Colour temperature of HIDs? proficience AUSTRALIA 17 06-19-2012 12:12 AM
