Old 04-20-2013, 12:39 PM   #1
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
Switching oils
So I was thinking of running 0w-30 in the summer or warmer months and 0w-20 in the winter, both oils is from Amsoil. Is there anything wrong wtih switching back and forth?
ArKiTeCkT is offline   Reply With Quote
Old 04-20-2013, 12:43 PM   #2
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
i run 5w30 in the summer and 0w20 in the winter. motul all day every day.
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 04-22-2013, 12:14 AM   #3
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Nothing wrong with switching but is there any point? Does it really get hot enough to warrant the use of a heavier oil? Which of the Amsoil range where you thinking of using?
SXE10 is offline   Reply With Quote
Old 04-22-2013, 12:42 AM   #4
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I second the above. What makes you think you have to change grades with the seasons?
Subie is offline   Reply With Quote
Old 04-22-2013, 01:25 AM   #5
reeves
What if you're constantly driving several hours at a time (no stopping) with oil temps hovering around ~225-230 F? This is what I've observed for my car when I make out of town trips.. which I do pretty frequently. I can't imagine it'll get any better once summer temps arrive.
Old 04-22-2013, 10:15 AM   #6
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
No.
Old 04-22-2013, 11:21 AM   #7
bluesubie
Drives: 2004 Subaru Forester 2.5XT
I'm guessing the OP is referring to the Signature Series (non API certified) since that is the only line to have a 0W-30.
It's fine switching oil grades for summer, but I would personally go with a less volatile oil over one with a higher viscosity unless the higher viscosity oil shows lower wear over several successive used oil analyses in your application (unless you have a built motor and/or track the car).
Among the Signature Series, the 5W-20 has the lowest NOACK volatility (with the exception of the 10W-30).
SS 0W-20 = 9.3% NOACK volatility
SS 0W-30 = 7.6% NOACK
SS 5W-20 = 5.5% NOACK That's even better than any Red Line xW-20 or xW-30 oil (most non API certified oils like Amsoil Signature and Red Line have better performance specs that API certified ones).
For the API Certified XL Line, the 5W-20 has a lower NOACK than the 0W-20 and 5W-30. More info on NOACK: http://www.pqiamerica.com/noack.htm
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
ArKiTeCkT (04-24-2013)
Old 04-24-2013, 11:57 AM   #8
ArKiTeCkT
ArKiTeCkT's Avatar
-Dennis
Ill stick with Amsoil 0W-30 SS. What oil are you using in your car?
Old 04-24-2013, 12:15 PM   #9
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
what about texas summers?
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 04-24-2013, 12:30 PM   #10
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Engine temperatures are the same regardless of where you live. Assuming your cooling system is working properly.
The oil is cooled by tranferring heat into the block and airflow over the oil pan.
Personally the only reason you need to run a higher volatility is if you are actually tracking/autox or driving the dog shit out of the car.
I live in San Antonio and I'm running 0w-20 Motul, I will probably switch back to Pennzoil Ultra when I change it.
Ranatsu is offline   Reply With Quote
Old 04-24-2013, 02:24 PM   #11
bluesubie
I use Motul 300V because I get it for free from a Subaru dealer using Subaru Mastercard rewards (Subaru bucks).
I usually change my mind monthly so I might pick up some Castrol Syntec 0W-40 next and save my new Subaru bucks for some new StopTech brake pads.
-Dennis
Was doing the transmission and diff oils today, when... what is this thing? Entroper Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 03-12-2013 12:40 AM
New Sponsor intro - Millers ultra low friction oils distributor MillersOilsUS Announcements, Contests, Giveaways 0 12-20-2012 10:41 AM
Anyone who had a Scion tC regret switching to the FR-S? redwing634 Scion FR-S / Toyota 86 GT86 General Forum 58 09-24-2012 12:57 PM
pricing for my 12 focus (switching to fr-s) jamesox Northwest 3 07-06-2012 10:29 AM
