| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2013 FR-S, 6MT, Ultramarine
DIY-Changing Clock/HVAC LEDs on FR-S
DISCLAIMER: I am NOT responsible for any damage you may do to your car.
DISCONNECT THE BATTERY!! Remove the screws in the cup holder area Pull straight up (towards the sky) on e-brake boot Remove shifter boot Disconnect the wire to the panel Pull boot up, and it will come off Remove 2 screws Remove panels (one on each side). Pull straight out (towards the outside of the car) Reach around, and push the USB/Aux plug out. Then unplug. Pull panel out Remove 2 screws Remove the center console. Remember, the 12V plug needs to be unplugged. Here is the center console area. Remove radio trim with plastic pry bar. The panel needs to come straight out, so take it slow! Remove 2 screws Remove side panels. The panels come straight back (towards the rear of the car. Grab the front and rear, and pull Remove 2 screws Pull panel out Remove wire plugs Remove the cable mounts. Each has 2 tabs as shown Take the panel inside to your bench. Remove the components from the panel. NOTE. If you have NOT done this before, take your time!! Then tabs break easily! First the clock. Remove the rear cover with 2 screws and 4 tabs First remove the screws circled in red. They are in tight, and are easier at this stage. Then remove the blue circled screws. Remove the board The LEDs on the right are for the airbag system. They are the same package as the rest of the LEDs. Choose your own adventure! It's up to you on how to access the LEDs under the white plastic piece under the LCD panel. Here is a picture of the LEDs that need to be replaced. Once complete, reassemble the clock. Now the HVAC. Remove the 2 white twist base lights, one in each of the mechanical units (left and right). This is a regular bulb with a yellow condom. Replace this with whatever you want. I chose to do below. Now the fan module. Remove the tabs shown, plus the ones on the other side. 6 tabs total. Remove cover. Remove white slider. Rotate/tip the circuit board to remove Remove the red circle LEDs. The blue one is for the defrost button, and can be changed at your discretion. After reassembling, you will have a RED clock and HVAC!! What LEDs did I use? 2PLCC size. Here is the link: Digi-Key After seeing the color, I might change the temperature knob to white. The red LED kills the blue color. **UPDATE (13JUN12)*** Night shots Last edited by Lil Abner; 06-13-2012 at 09:22 PM. Reason: Added Pictures |
| The Following 61 Users Say Thank You to Lil Abner For This Useful Post: | Asphalt~86 (12-25-2012), Bonburner (07-25-2012), brian_c_m (11-07-2012), BRZranger (07-24-2012), Chaetagnath (06-16-2013), Chenslee (06-11-2012), chulooz (06-10-2012), civicdrivr (06-14-2012), colHolm (06-10-2012), CxG (04-01-2017), Dadhawk (06-10-2012), DAEMANO (01-09-2018), DjDATZ (11-05-2013), dj_mallu (07-25-2012), dsgerbc (06-10-2012), encity5 (06-10-2012), enjoi23 (11-24-2012), EvoFanatic (07-25-2012), Fascist Fish (06-10-2012), finch1750 (11-07-2012), Fly Guy (07-09-2012), FriedRicr (03-27-2013), GaN-MaN (07-23-2012), Guff (06-11-2012), Hawk77FT (01-10-2013), Ice_Man (07-17-2012), Jayp (06-10-2012), JeffForSale! (04-06-2025), JollyJON (07-25-2012), Khyron686 (06-24-2012), kludger (12-19-2012), kwood9000 (06-12-2012), lordtakuban (07-25-2012), luxmn (06-10-2012), M&M_Hwy9 (06-13-2012), mattles (06-10-2012), mezdup (06-24-2012), michaelahess (06-10-2012), Mooseknuckle44 (04-14-2014), Nails (03-11-2017), NeedsmoreCowbell (06-12-2012), nibor33 (06-11-2012), Pdub86 (08-15-2012), punchdrunkjuice (06-10-2012), roguetadhg (07-02-2012), RRnold (06-11-2012), scionfrs2014 (04-16-2014), Scooby (06-12-2012), Shipwreck (03-30-2013), spgrizz22 (03-27-2013), SuperTom (03-12-2022), TheRipler (09-02-2012), TPO (06-17-2012), ts87 (09-02-2013), Turbowned (09-07-2012), Username (06-28-2012), WingsofWar (06-10-2012), WolfSongX (12-20-2012), YinYang1980 (07-01-2012), zohare (11-22-2012), zoomzoomers (08-25-2012) |
#2 |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Most impressive! Great write-up!
#3 |
Registered you sir
Drives: 99 impreza coupe
Killer job. Night pics now!
#4 |
I will try and get some once the sun goes down.
#5 |
Drives: Scion Fr-s
Bad as* I was going to do the same thing!!! I did it on my Tc and was thinking of doing it on the Fr-s. Could you take some pics of the removal process?
#6 |
#7 |
Drives: Scion Fr-s
#8 |
#9 |
Drives: Scion Fr-s
#10 |
#11 |
Drives: Scion Fr-s
Lol I tried to give there new browser a chance and it failed me yet again.
Do you have and idea of what size bulb it might be? |
#12 |
Drives: Beater
Bravo!
read the leds are smds so u had to solder the new ones on? I was hoping it would just be plug n play |
#13 | |
| The Following User Says Thank You to Lil Abner For This Useful Post: | Juanito08 (06-10-2012) |
#14 |
| Changing Premium to Limited? | zygrene | BRZ First-Gen (2012+) — General Topics | 32 | 10-09-2012 11:58 AM |
| I'm changing my order from World Rally Blue to Lightning Red | Subie | BRZ First-Gen (2012+) — General Topics | 26 | 06-12-2012 12:59 PM |
| Changing order, does it require a new order? | xwd | BRZ First-Gen (2012+) — General Topics | 11 | 03-21-2012 12:57 PM |
| LEDs that convert heat directly into light... | serialk11r | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 03-10-2012 12:08 PM |
