Drives: Asphalt FRS
This car really hates the cold weather
I've never had a car that was so finicky in the cold weather. I tend to start my cars and let them idle for ~10 minutes on a cold day like today (around 18*). Ran out this morning to start her up and left her idling for a while during my morning routine.
When I got in I realized it had only gotten a little over the quarter mark on the heat gauge, turned on torque in my phone to check if the coolant was over 60* and it was sitting at 62 so I figured it'd be safe to get moving for the day. I park on a pretty steep incline, around 30 degrees, and popped into reverse, on a normal day I don't need to press the gas much at all to get out of my drive way, maybe a bit if I have to cut the wheel or something. However this morning when I shifted into reverse (AT) the car literally shuttered and rolled back at a speed too low to even register on the speedometer. I pressed on the gas a bit and felt how sluggish the engine was to move the car, it also made a strange sound in reverse, it almost sounded like the timing belt or something, not a squeak but a kind of grinding sound coupled with a wooshing sound that almost sounded like the intake sucking in air at WOT. (I was nowhere near WOT btw) Got out of my driveway and popped into drive, car still felt sluggish but it seemed to melt away after a few minutes of driving... Is this a problem everyone is experiencing? It's mildly concerning because I'm almost afraid to drive my car unless it idles for enough time to get the coolant over 65 degrees, this would obviously be a huge inconvenience. I'm considering switching to a better oil for the next few months, and recommendations, I have 0w-20 synthetic in now, but would consider putting a better winter oil in. |
#2 | |
Drives: WRB BRZ
#3 |
Drives: red frs
My manual trans car doesn't like to start when I leave it sit out in the cold at work.
It cranked for a solid 7 seconds last night before firing. |
| The Following 2 Users Say Thank You to Shit Luck For This Useful Post: | Brzce (01-23-2013) |
#4 | |
Drives: Asphalt FRS
#5 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
I've noticed a few groans from mine the last couple mornings. Dipping down into the low teens. But don't know that any of my automobiles haven't had some cold weather symptoms. I don't let it idle, I start and go, keeping the revs to a minimum.
Yesterday after initial start it backfired 2 or 3 times through the intake right after starting. MT is very stiff and 2nd gear is very hard to hit. I've resorted to double clutching till it warms up. The tires are stiff and out of round till warmed up. Nothing major. |
| The Following User Says Thank You to FRSFirestorm For This Useful Post: | Brzce (01-23-2013) |
#6 |
Drives: Dodge Omni
-35c here this morning, car fired up and ran fine.
The radio will not power up if the temp is below -25c however |
| The Following User Says Thank You to waynegro For This Useful Post: | Rayme (01-23-2013) |
#7 | |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
| The Following 6 Users Say Thank You to pheoxs For This Useful Post: | b.e (01-23-2013), Craig (01-23-2013), dsgerbc (01-24-2013), neutron256 (01-24-2013), Ryephile (01-23-2013), Spaceywilly (01-23-2013) |
#8 |
Drives: 2007 WRX
I agree with pheoxs. Sounds like your transmission is cold. The fluid in there is thick and will lead to sluggish feel and unsettling noises. Just be gentle while it warms up after you start driving and I wouldn't worry about it.
#9 |
Drives: Scion FRS Ht Lva(AT)
0W-20 is pretty much as low as you can go viscosity grade wise! I don't think that would be the problem.
#10 |
Gettin SIKKY sideways
That depends what they calibrated the gauge to. I'd be curious to see what it is compared to actual temps. My other car, temp shows at anything past 75 and has about a solid 50-75 degree window of "good" on the stock gauge. Operating temp is 180. Not going to hurt anything by warming it up more. Plus you can warm up then :P But yeah, trans fluid is still cold at that point |
#11 |
Hot Dog
Drives: quicker than arghx7
Quoted for good wisdom. Just get in the car and drive modestly until everything warms up. It's the exact same story when going to the track; you do a warm-up lap to get everything up to temp, not just engine coolant.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#12 |
Drives: Attitude
Stop warming it up by idling. Start warming it up by driving gingerly.
FWIW, it was ~20 degrees F yesterday and the car started fine. Let it sit for ~14 hours as it got colder (single digit temps this morning) and it started fine. Windows didn't even freeze! Of course, 2nd gear did its thing as it always does. |
| The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post: | Spaceywilly (01-23-2013), Subie (01-23-2013) |
#13 |
Drives: 2013 FR-S Hot Lava
When the temperature is just above 0*, mine starts up without problems but takes a while to settle down at the normal idle.
When the temp falls below 0*, I have experienced the engine "stumble" for a fraction of a second a few times right after I fire it up. This car is worse than my carbed bike in the cold...
Live to drive another day
#14 | |
| The Following 2 Users Say Thank You to mhigham For This Useful Post: | Gords_zenith (01-25-2013), Tim_Asphalt_FRS (01-23-2013) |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| rattling in cold weather | mezdup | Issues | Warranty | Recalls / TSB | 2 | 01-22-2013 10:32 AM |
| cold weather & remote starter | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 11-10-2012 07:03 AM |
| Cold / Wet weather brake issue? | Ingen | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-29-2012 12:42 PM |
| Pretty sure car hates the cold weather | HuntingtonFRS | Issues | Warranty | Recalls / TSB | 28 | 10-21-2012 05:52 PM |
