Old 12-14-2012, 05:09 PM   #1
BRZnut
Drives: BRZ DGM Limited
Help me understand the BRZ/FRS engine!
Have had a BRZ for 2 weeks and want to have a better understanding of this engine:
Other than the two injection systems and the boxer design, how is this engine new and different??
Also, I don't understand what the Cams do and why they keep throwing the CEL...can someone explain??
Old 12-14-2012, 05:20 PM   #2
Opposed
Drives: 2013 Asphalt FR-S
Besides the duel injection, and high compression, and low center of gravity, there is nothing really new and advanced about this engine.
Cams have lobes on them, which are driven by a chain or belt (chain in this engine) connected to the crankshaft. The lobes push down onto the intake and exhaust valves which allows air and fuel in, and exhaust out. Our particular cams have variable timing. Meaning, the computer can adjust the timing on when they valves are opened for performance and efficiency reasons. They are controlled by oil pressure. Some cars have an oil pressure issue, or the varriable system gets stuck causeing the engine to run poorly and thus throwing a CEL. Again, this is just as simple as I can explain it. But here is a video of cams working if that helps...
[ame="http://www.youtube.com/watch?v=ry2nP7I315M"]Variable CAM Timing - YouTube[/ame]
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
The Following User Says Thank You to Opposed For This Useful Post:
ToxicSneakers (12-14-2012)
Old 12-14-2012, 06:38 PM   #3
2forme
Well the technologies used in the engine parts allow it to handle more power than a run of the mill motor. You should look at the crawford tear down.
Old 12-14-2012, 07:25 PM   #4
BRZnut
Good stuff..thanks. Since the oil control CAM system in the BRZ/FRS is nothing new, wonder why there are having issue with it??
Old 12-14-2012, 07:31 PM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I think most of these issues were before the new ecu reflash/computer problem. Dealers were just replacing whatever was related to the CEL codes at that time..someone correct me if I'm wrong.
Rayme is offline   Reply With Quote
Old 12-14-2012, 07:38 PM   #6
OrbitalEllipses
Drives: Attitude
A TSB came out to replace cam gears and associated parts...it was quickly pulled for many reasons. One of those reasons was probably because dealers were popping engines due to improper installation.
Old 12-14-2012, 09:39 PM   #7
BRZnut
no you are right..thats how its played out so far. But I've read that some think the ECU upgrade is just an attempt to cover over some sort of mechanical problem of the Cam system. Wonder what the real problem is and why.
Also wonder if the oil cam system could be change to the third type shown in the video above that is all electric if the ECU change does not fix the issue.
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 09:12 PM
I didn't like the AT and I'm trying to understand why fiveoneoh BRZ First-Gen (2012+) — General Topics 97 06-11-2013 02:34 PM
I Think I Finally Understand How People Crash 636 Scion FR-S / Toyota 86 GT86 General Forum 103 05-28-2013 12:36 AM
What I just don't understand... Liquidcell Scion FR-S / Toyota 86 GT86 General Forum 35 08-30-2012 09:38 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
