Old 03-21-2022, 02:07 AM   #1
gpvecchi
gpvecchi's Avatar
Second lambda extender
Can you please suggest me where to buy, or find the plugs to make it?
Thank you
Old 03-21-2022, 03:05 AM   #2
tomm.brz
Drives: brz 2017 hksv2
secondary O2 spacer doesn't work good on this platform
It will mess with the A/F#3 correction, unless you disable it, so your cruising and transient afr will be a mess
It will trigger a CEL after a while, even if you disable the A/F#3 corrections, can t remember the code but it is the DTC that relates to "sensor 2 bank1 too lean".. again, unless you disable the DTC (and if ecutek found the DTC in first place)
It MAYBE corrects the P0420 cat DTC, which requires anyway a single click on the tune to be deactivated and doesn't influence anything else
When you disable A/f#3 and all DTCs you can even delete the O2 sensor, so the spacer is useless at this point
Can't help you to find a good O2 spacer, but if you use it, use it temporary because it messes things
Old 03-21-2022, 08:37 AM   #3
gpvecchi
gpvecchi's Avatar
Sorry, I hadn't been clear. I don't mean a spacer to prevent CEL, I meant a wire extender...
Old 03-21-2022, 10:13 AM   #4
whataboutbob
AutoX-10/10ths every run
This is the company I used to have an extension made: https://iwireusa.com/
Build thread:Here
OFT V1 + OBD Extender cable with on/off switch paintdude258 Audio/Visual, Electronics, Infotainment, NAV 1 02-11-2019 11:40 PM
Emission Inspection OBD2 Lambda stefodrom Software Tuning 10 04-05-2018 01:44 AM
O2 Lambda Sensor Deactivation? stefodrom Software Tuning 9 09-30-2017 10:10 AM
GS:Gold we are likewise shifter extender. jay92 Interior Parts (Incl. Lighting) 8 09-27-2016 12:37 AM
O2 Sensor Extender & Spacer Donbrz Engine, Exhaust, Transmission 1 08-03-2015 10:46 PM
