Old 10-18-2012, 04:01 AM   #1
jaiminsong
Drives: civic
hid light levels
Is there anyway to raise it up higher than the current limit? I wish it could go a bit higher so I can see more in front of me...I know it's there for safety reasons, but just a LITTLE bit higher. Is this possible?
jaiminsong is offline   Reply With Quote
Old 10-18-2012, 04:03 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
im assuming you have an FR-S?
convert to BRZ headlights or GT86 headlights with level adjustments
86_ZN6 is offline   Reply With Quote
Old 10-18-2012, 04:04 AM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
The level adjustments only allows you to go lower, 0 being at normal height. lol
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 10-18-2012, 04:05 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
ah ok. well i guess he needs to do a custom projector then that has a higher beam output
Old 10-18-2012, 04:13 AM   #5
jaiminsong
Drives: civic
I have a brz. It's at the position where the lever raises the lights to the highest. But I want it to go higher so I can see more out in front of me at night.
Old 10-18-2012, 04:18 AM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
You can use high beam...but that's your only other option, unless you want to mod/manually mess around with it.
I; however, do not recommend you doing this because it will blind the on-coming traffic... and in most places, illegal.
Don't know what your situation is but I find that our headlights are really bright... and they light up the roads pretty well.
2000 MR-S 5MT
2010-2012
Old 10-18-2012, 04:40 AM   #7
shrike92
shrike92's Avatar
Drives: '13 CBS BRZ
Yeah I have to agree. Even on 0 I really feel for the people coming up the opposite side of a hill because my lights are like directly in their faces. The users's manual has different situations and the recommended light level setting for each.
When I first started driving it I wanted it higher as well but after about 1k miles I feel like it's just right.
shrike92 is offline   Reply With Quote
The Following User Says Thank You to shrike92 For This Useful Post:
brz7400 (10-18-2012)
Old 10-18-2012, 05:16 AM   #8
jmaryt
Drives: 2012 honda civic ex
yes! i believe it is set at the highest level at 0 for a very good reason
any higher,and you risk those "hids" blinding the sh*t out of the on coming driver! ..just sayin'
jmaryt is offline   Reply With Quote
Old 10-18-2012, 08:51 AM   #9
robotvoice
Drives: 07 STI
Your headlights have adjustment screws on the back to manually raise and lower the vertical level of the projectors inside the lights. Set your lights on the highest setting from inside the cabin, then dial them in with the adjustment screws to your desired height. This way, you can still lower them a bit if you have cargo or passengers in the back so you don't blind oncoming traffic.
The location of the adjustment screws should be in the service manual. I am sure there are threads on here too that walk you through the process.
robotvoice is offline   Reply With Quote
Old 10-18-2012, 12:40 PM   #10
dsgerbc
Drives: BRZ(sold), STI
Dump a body or something heavy in your trunk. Problem solved. Also yeilds more grip for winter
The Following User Says Thank You to dsgerbc For This Useful Post:
Sc0ob_do0D (10-18-2012)
Old 10-18-2012, 01:54 PM   #11
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
I hate to be the guy on either side (opposite or in front) get blinded by your intended raised headlights. Surely you wouldn't want to induce any more road rages out there.
I find that setting it to 0 is plenty high enough and projects far enough in a city environment. I set mine to 1 because I don't want to blind other drivers.
Be courteous to your fellow drivers, don't raise your headlight (unless you ask for trouble).
jflBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to jflBRZ For This Useful Post:
Mobius357 (10-18-2012), shrike92 (10-18-2012)
Old 10-18-2012, 06:01 PM   #12
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
The low and high beams look like they are the same actual beam, the low beam just has the top half of the beam blocked off. I too feel back for other people when I'm going over hills, love how bright the lights are though. There are times I wish I had a little more spill light. Beyond the abrupt line where the low beams end, I feel kinda blind.
Mobius357 is offline   Reply With Quote
Old 10-18-2012, 06:03 PM   #13
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
I found that I was getting flashed when I had mine set to 0 so I currently have them at 1. Still plenty of light to see what's in front of me.
rapidcars is offline   Reply With Quote
Old 10-19-2012, 01:21 AM   #14
Lytheum
Drives: 2013 BRZ Premium 6MT
if there is an adjustment screw find a wall and mark where the beam sits. then turn it down to 1 and adjust them up to match the previous mark. now when you go back to 0 it will be just a bit higher and adjusting back to 1 will be the original setting.
hopefully i typed all that right lol
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
The Following User Says Thank You to Lytheum For This Useful Post:
adprokid (10-20-2012)
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 11:17 AM
Radiation levels adam Scion FR-S / Toyota 86 GT86 General Forum 7 07-01-2012 03:32 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 12:21 PM
FR-S Trim levels... nate89 Scion FR-S / Toyota 86 GT86 General Forum 155 08-05-2010 02:51 AM
