Old 07-05-2013, 04:28 PM   #1
Slash
Slash's Avatar
Drives: 2013 FRS
Rota Grid fitment +complication
Alright, new to forum. Just traded in my 2010 Mazdaspeed 3 for my FRS Saturday blah blah it's awesome.
Have my old set of Grids off the MS3 which are obviously 5x114.3 vs our 5x100.
Now these babies are 18x8.5 +44 and from my measurements should be just at or slightly below "flush". Issue being that instead of selling these and taking a huge loss by buying 5x100s I'd prefer to try some adapter spacers. Now would these things sit all mexiflush like that or what? I've got some experience with bolt on spacers IE, been running them for 5 years on my Silverado, and used them on a few 240sx's I've owned in the past. I've seriously been trying my hardest to avoid posting on here about it but its killing me trying to decide on my own. So in conclusion, 18x8.5 +44 with a 25mm spacer? Or sell and pick up some 5x100's? I'm thinking some XXR 535s, but what offset do you guys recommend those in for a "flush" look? Stagger them as well?
Slash is offline   Reply With Quote
Old 07-05-2013, 04:50 PM   #2
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
my 18x9 +35 are pretty much "flush" so you would be sitting about a inch further in then what "flush" would be, so if you get the conversion from 5x100 to 5x114 you would probably add a inch of thickness which would put it pretty close to "flush"... just sell em and get new wheels is my opinion :-P
JesseE is offline   Reply With Quote
Old 07-05-2013, 04:59 PM   #3
Slash
Slash's Avatar
Drives: 2013 FRS
Exactly what I figured. Thanks just needed a verification.
Sent from my SGH-T999 using Tapatalk 2
Old 07-05-2013, 06:03 PM   #4
donutfilling
donutfilling's Avatar
Drives: frs
get a 10mm conversion spacer
donutfilling is offline   Reply With Quote
The Following User Says Thank You to donutfilling For This Useful Post:
dori. (07-06-2013)
Old 07-05-2013, 06:34 PM   #5
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
10mm is not an inch learn your conversions...
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 07-05-2013, 07:34 PM   #6
Slash
Slash's Avatar
Drives: 2013 FRS
How would a 10mm conversion spacer work? I'd imagine the studs are littleee longer than 10mm.
Old 07-05-2013, 08:37 PM   #7
FirestormFRS
.393". See how easy that was and I didn't come across as a jerk.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
Enraged21 (07-06-2013)
Old 07-06-2013, 11:26 AM   #8
JesseE
JesseE's Avatar
If you could read correctly, his wheels have less width, and then the added 10mm difference in offset.
Old 07-06-2013, 01:58 PM   #9
Slash
Slash's Avatar
Drives: 2013 FRS
Hai guise take it easy the wheels are for sale hahah.
Old 07-06-2013, 05:55 PM   #10
donutfilling
Drives: frs
He said 1 inch because he said 25mm spacers. Project Kics sells 10mm conversion spacers, i believe people run them fine.
Old 07-06-2013, 06:16 PM   #11
Slash
Slash's Avatar
Drives: 2013 FRS
Is that enough stud after trimming to get a solid bite?
Group Buy - Rota Slipstreams or Rota Grid davidsolarbell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-17-2013 01:04 PM
Wheel Directory: Rota Grid 2 17x8.0 +38 stvrjs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-02-2013 05:08 AM
WTB : rota grid 18 8.5 +44 jshadeck Wheels and Tires 3 06-12-2013 03:01 PM
Rota grid 17x9 +35 MattF Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 02-10-2013 11:33 AM
Rota Grid 18x10 30et Nizz300Ft86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-15-2012 12:34 AM
