Old 07-19-2013, 03:04 AM   #1
Yruyur
Yruyur's Avatar
Intake Snorkel Diameter Mod Question
I am no expert by far. Would like some input on this.
I have an Airaid that uses the stock snorkel to pull air from inside the bumper. The install manual says for max hp to remove the snorkel. If I were to remove it there would be a small gap allowing air to be pulled from the engine bay as the snorkel inserts itself a little into the Airaid.
I want to use the stock snorkel to pull the air from inside the bumper for more of a cai but found it is bottlenecked at the opening. Measures at 2.7 inches diameter at the opening. Im no expert but if we have a 3 inch throttle body shouldn't the snorkel be the same?
So thinking of cutting the snorkel off and heating and molding the plastic into a velocity stack or adding one while keeping at least a 3 inch diameter.
My first choice is to remove both the chambers and cut at the 3.5 inch line. Not concerned about noise and a tuner should be able to work out any afr ratios issues if any come up.
I know there are after market ones available but im cheap.
Ideas, opinions, suggestions?
Measurements are the diameter based on the outside circumference.
Old 07-19-2013, 03:48 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just do it as I'm guessing you will anyway. Shouldn't have any impact on your tune at all though.
But consider this, Toyota/Subaru could have designed it with a bigger opening, so why did they fit it with an "undersized" part? 2.7" is wide enough to cope with more horsepower than our cars will see N/A.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 3 Users Say Thank You to Kodename47 For This Useful Post:
Teseo (07-09-2024), Yruyur (07-19-2013)
Old 07-19-2013, 02:11 PM   #3
PSJohnDoe
You're going to need to talk to an engineer familiar with the mechanics in question but you may not improve performance by cutting it at the 3" diameter mark. There may be a purpose to the shape that you don't understand. I don't know enough about fluid mechanics to say either way, but I'm guessing they aren't randomly drawing shapes on paper and putting them into production.
PSJohnDoe is offline   Reply With Quote
The Following User Says Thank You to PSJohnDoe For This Useful Post:
Yruyur (07-19-2013)
Old 07-19-2013, 03:25 PM   #4
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Glad my old parts are going to good use, nice meeting you last night too.
IceFyre13th is offline   Reply With Quote
The Following User Says Thank You to IceFyre13th For This Useful Post:
Yruyur (07-19-2013)
Old 07-20-2013, 07:27 PM   #5
Yruyur
Yruyur's Avatar
So I got around to cutting the snorkel. Used a hand saw that took about a minute. The cut is angled down a tad towards the grill. I heated the edges over the stove and curled the ends out to help create a velocity stack. Needs some better sand paper to smooth everything out tonight.
This cut ended up giving me a 3.8 inch diameter.
Sent from a Motorola DynaTAC 8000X
The Following User Says Thank You to Yruyur For This Useful Post:
DJCarbine (07-21-2013)
Old 07-21-2013, 12:38 PM   #6
DJCarbine
Thupercharged
DJCarbine's Avatar
Interesting. I've got a vortech kit that also uses the factory snorkel.... I also have a 3 inch velocity stack laying around.
I wonder if there would be any gains from this
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-21-2013, 03:05 PM   #7
Yruyur
Yruyur's Avatar
Found @2forme was running an extremely similar chopped snorkel. He found more gain via dyno by removing it all together.
http://www.ft86club.com/forums/showthread.php?p=466160
AFe Intake -with or without snorkel? gms Engine, Exhaust, Transmission 2 10-25-2020 05:23 PM
Airaid Intake Install with Snorkel Delete DIY W2 DIY (Do-It-Yourself) Guides 28 09-14-2016 06:42 PM
Changing Intake Snorkel JDKane527 Engine, Exhaust, Transmission 10 05-08-2013 12:27 AM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 04:14 PM
Bigger Intake Snorkel Duct? Anorexic 86 Engine, Exhaust, Transmission 8 01-29-2013 02:00 PM
