Old 08-02-2017, 09:49 PM   #1
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
2013 BRZ Rebuild, totalled to track car.
2013 Subaru BRZ Premium - M/T
Mods: (Updated 10/20/2023)
Mishimoto Performance Aluminum Radiator, MMRAD-BRZ-13
Mishimoto Thermostatic Oil Cooler Kit, MMOC-BRZ-13
Radium Engineering Master Cylinder Brace, 20-0104-01
Radium Engineering Oil Catch Can
2 Sets: Enkei RPF1 Wheels, 17"x9", +35, 1 set Gunmetal, 1 set Victory Blue
ARP Extended Lug Studs
Muteki SR48 Open End Lug Nuts
RaceComp Engineering Tarmac 2 Clubsport Coilovers, 600# F Springs, 650# R Springs
Raceseng CasCam - Caster & Camber Plates (Front)
Raceseng 1" Upper Mounts (Rear)
Buddy Club Adjustable Rear Lower Control Arms
Essex Parts Designed AP Racing Competition Sprint Brake Kit
Spiegler Front & Rear Stainless Steel Brake Lines
Ferodo DS1-11 Brake Pads F&R
DBA 4000 Series T-Slotted Rear Rotors
JDL Auto Design UEL Header
JDL Auto Design Over/Front Pipe Combo
Invidia Full Titanium Catback Race Exhaust
HRi Tuning EcuTek Tune by James
Whiteline KDT925 Rear Differential Mount Bushing Kit
Whiteline KDT922 Rear Sub Frame Bushing Kit
Corner Balance, Alignment and Suspension Setup by Speed Syndicate
Perrin Intake Tube & Sound Tube Delete
Geraldjustprojects.com Trac-Box
Cusco 20mm Solid Front Sway Bar from CounterSpace Garage
Cusco 16mm Hollow Rear Sway Bar from CounterSpace Garage
Cusco LR Axle Heat Shield
Super-Pro 12mm Adjustable Front Sway bar Links 160mm #TRC12160 from FTSpeed
MeLe Design Firm Battery Box
XS Power Li-S680 4.5lb Lightweight Battery from MeLe Design Firm
2015 OEM Underbody Aero Panel Set
Kartboy Transmission Mount Insert
TrackSpec Motorsports Hood Vents
Gutted Interior panels/seats/carpet
A/C System Removed
JDM A/C Delete Bracket
Tires:
Dry Set: Hoosier R7 Tires, 225/45R17, from Track Day Tire
Damp/Dry Set: Goodyear Eagle F1 Supercar 3, 245/45R17 from TireRack
Fluids:
Castrol EDGE A3/B4 0W-30 Advanced Full Synthetic Motor Oil
Redline MT-90, 75W90 Gear Oil (Transmission)
Motul Gear 300, 75W90 Gear Oil (Rear Diff)
AP Racing Radi-Cal R2 Brake Fluid
Subaru Super Coolant
Redline CV2 - CV Axle Grease
Safety:
Autopower Race 4-Point Roll Bar
OMP HTE-R Seats
OMP 0204 6-Point Blue Pull Up Harness Belts
OMP Seat Sliders
Race Safety Steel Side Seat Mounts
Hans Sport III
Stilo ST5 Composite Helmet
Sparco Suede Steering Wheel
NRG Hub Adapter & Quick Release Kit
Motorsports Organizations:
Chin Track Days - The Leader in High Performance Driver Education
Current Weight: Car, no driver - wet, full fuel = 2,640 lbs
The Story:
Back when the BRZ first came out I got the 2nd one delivered to my local dealer.. @Dave-ROR got the 1st....
I was pretty active here in the early days, modded the BRZ a bit and loved driving it. Though a very fun car that I really enjoyed, it had it's limitations as a "family" car and after close to 2 years and 30,000 miles I traded it in on something a little bit bigger...
Fast forward to this past May, my daughter graduated high school and I found myself with the time to start attending motorsports events again and participated in a track day using my slightly-modded "family car", Legacy 3.6R
After 2 track events the bug had gotten me again, I wanted to do more but the wear & cost of consumables (pads, rotors, tires, etc) for the Legacy 3.6 was concerning. I got to spend some time with Chin Track Days, track prepped 2013 BRZ and I knew I wanted one again.
So by the end of June I was on the hunt for an inexpensive BRZ/FR-S as a 2nd car that I could use for track days & autocrosses. In early July I found a 2013 BRZ Premium with only 24,000 miles that had been "totaled" in an accident involving a curb and an off-road excursion. I figured I could tackle most of the repairs myself and then get a Florida Salvage title once it was repaired.
It just so happened that this BRZ was now in possession of one of the Chin Track Days instructors who purchased it as a parts car after the Chin BRZ had an off track incident and was offering the rest of the car (now missing a few more parts) for sale.
Opie is offline   Reply With Quote
Old 08-02-2017, 09:52 PM   #2
Opie
Opie's Avatar
Old 08-02-2017, 09:57 PM   #3
Opie
Opie's Avatar
And had some issues on the floor pan / brake lines
So we agreed on a price and on July 15th Dave-ROR & I went to Atlanta, loaded it up and took it home to Florida
Huge Thanks to Dave-ROR for the assistance and use of his truck & trailer!
Old 08-02-2017, 10:02 PM   #4
Opie
Opie's Avatar
Home at last!
Car had the seats and carpet in it, I got those removed on the first day home to address the floor pan repairs. However the dash had been stripped of parts by the previous owner to repair the other BRZ or to sell to help pay for the repairs.
Old 08-02-2017, 10:04 PM   #5
Opie
Opie's Avatar
A mallet and some sweat and the floor pan is in better shape, just gotta weld some patch panels...
Old 08-02-2017, 10:12 PM   #6
Opie
Opie's Avatar
Head underneath the car to formulate a game plan to fix the brake lines and weatherproof the floor pan and I find some unexpected damage.
Compared to what it should look like
After consulting two body shops who both said they didn't want to touch that because of it's location and difficulty due to overlapping panels I decided to take it on myself. Ordered new sheet metal from Subaru and cut out the part I needed, this doesn't look to be as bad as the body shops made it out to be...
Ready to weld in, just gotta get the brake lines and fuel lines down for clearance and safety, plus they need to be replaced anyway.
In the mean time, I got a door from the salvage yard and got it mounted.
Old 08-02-2017, 10:16 PM   #7
Opie
Opie's Avatar
Since the door was on, lets knock out the dash and see if this thing runs.
And!
Old 08-02-2017, 10:22 PM   #8
Opie
Opie's Avatar
And on to the LH Fender...
Looks like I'll need a small wiring repair...
Old 08-02-2017, 10:25 PM   #9
Opie
Opie's Avatar
Old 08-02-2017, 10:27 PM   #10
Opie
Opie's Avatar
Pretty good progress in 17 days, hope to get the floor pan completed and the interior reinstalled this weekend and attempt to get the suspension arm mount completed as well, then I can start reassembling and get these parts out of my guest room...
Old 08-03-2017, 06:56 PM   #11
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Ah. It feels like Impreza.net again. Definitely following and thanks for sharing, Opie!
dowroa is offline   Reply With Quote
Old 08-04-2017, 09:46 AM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
How'd I miss this thread?
Good work!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-04-2017, 09:15 PM   #13
Opie
Opie's Avatar
Thanks again for the help Dave! Trying to get this on the road before the October Sebring event.
Old 08-06-2017, 08:59 PM   #14
Opie
Opie's Avatar
Huge amount of progress on the car this weekend! Had a co-worker come over that had much better welding skills than me and we knocked out the two big things on the list, welded up the floorboard and the suspension mount.
NORGP GT86 just for Track Rebuild Panamaniac Member's Car Journals 25 12-06-2019 08:41 AM
History of my GS-R.. and rebuild.. my now-current track car. Dave-ROR Other Vehicles & General Automotive Discussions 35 12-12-2013 08:02 PM
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 11:36 AM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
FS: 2013 Totalled BRZ FS (~5,000 miles) eklipz98 Northern California 45 02-03-2013 01:16 AM
