Old 01-01-2025, 03:38 PM   #1
im.rocketeer
Drives: 2013 Toyota-86
HELP!! Installing Piston Ring (Oil Control Rail without Tab)
Hi all, so does anyone have experience with installing rings on OEM pistons. I got these dnj piston ring set but for some reason the oil control rails (both top and bottom) does not have the tabs that locks the ring in place. I checked if I got the wrong product but everything checked out. so my question is how do I go forward with the installation with product in my hand.
been waiting for the manufacturer to replay back to my email but I hope I get some feedback from here!
Thank you!
Last edited by im.rocketeer; 01-01-2025 at 07:41 PM. Reason: for everyone to understand the subject matter.
im.rocketeer is offline   Reply With Quote
The Following User Says Thank You to im.rocketeer For This Useful Post:
humfrz (01-02-2025)
Old 01-01-2025, 08:05 PM   #2
Eaton PSI
Drives: 2013 86
Those tabs are very rarely seen on any rings. Just assemble new ones as normal.
Eaton PSI is offline   Reply With Quote
The Following User Says Thank You to Eaton PSI For This Useful Post:
im.rocketeer (01-01-2025)
Old 01-01-2025, 10:18 PM   #3
im.rocketeer
Yeah mostly seen on Boxer engines but Subaru seems to be very specific about this tab. I wonder why a manufacturer would miss out on such specification.
Old 01-01-2025, 10:23 PM   #4
im.rocketeer
This is the instruction manual.
Old 01-01-2025, 11:55 PM   #5
Eaton PSI
Drives: 2013 86
Rings very slowly rotate as the engine is running. I guess they're trying to avoid having the oil ring gap end up at the lower side of the piston as oil can seep through the gap when the engine is stopped. Boxer engines often give a puff of smoke at startup because of this.
im.rocketeer (01-02-2025)
Old 01-02-2025, 12:25 AM   #6
im.rocketeer
So, technically installing it wont be causing fatal engine issues other than the start up smoke?
btw, really thankful for your input here!
Old 01-02-2025, 01:49 AM   #7
Eaton PSI
Drives: 2013 86
No fatal issues. I run custom made pistons in mine with a bit looser clearance and aftermarket rings. I get a puff of smoke once every 8 or 10 starts.
Old 01-02-2025, 04:55 AM   #8
im.rocketeer
Wonderful! cant thank you enough for your time brother!
Old 01-02-2025, 12:27 PM   #9
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
It won't be a major issue but you will burn more oil if the gap droops down towards the bottom.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Old 01-02-2025, 02:07 PM   #10
im.rocketeer
if you dont mind me asking but
can you please explain what you mean by the gap dropping down?
Old 01-02-2025, 03:30 PM   #11
Xero-Limit
Xero-Limit's Avatar
Gap in the oil rings. They can rotate over time without tangs. Again, minor in the grand scheme of things.
Old 01-02-2025, 11:13 PM   #12
Of course.
First go to a hardware store and purchase 2 large hose camps that wiil go over the piston.
Stop at the grocery and buy a can of beans (that is slightly larger than the piston).
Empty the can of beans and cut both ends out of the can.
Cut the can open longways.
Place the rings on the piston, cover piston with the can with rings in place and clamp down tight.
Place the piston on top of the cylinder block.
Gently pound the piston out of the can into the cylinder block using the wooden handle of a large hammer.
Yes, I am OK, it's just a slow day in Puyallup -
Old 01-04-2025, 06:13 PM   #13
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I'd throw those DNJ rings in the garbage...but if you insist on using them, be sure you properly file fit them with the proper end gap...they are not ready to just install....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
im.rocketeer (01-07-2025)
Old 01-07-2025, 09:25 AM   #14
im.rocketeer
Haha garbage is where it ended up in my case.. what a weird product indeed.. in my case it didn't seem to fit the cylinder cause of the width of the oil ring being larger.. now I have to order new set of rings but seems like its easier to find a Toyota OEM than Subaru's.. can anybody help me find the Toyota's part number of 12033-AC300 <-Subaru OEM
Opie (01-07-2025)
engine block, installation, piston, piston rings, reference
Seat rail width fafaforza Cosmetic Modification (Interior/Exterior/Lighting) 3 10-14-2017 02:12 PM
WTB Armrest w/ Rail Twig Want-To-Buy Requests 0 07-09-2015 02:00 PM
Hit the exit ramp rail :( dad&sonFRS Scion FR-S / Toyota 86 GT86 General Forum 123 03-31-2014 12:58 PM
CP Rail on strike. Where is my BRZ/FRS? percyng CANADA 15 05-28-2012 10:17 PM
