Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-11-2021, 06:10 PM   #1
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
How to install an auto-dimming mirror for the Subaru BRZ 2022
Hey guys, I made a video tutorial on how to install the auto-dimming mirror in your Subaru BRZ 2022. I tried to get straight to the point. Let me know if this helped you!
PhatFreshPrince is offline   Reply With Quote
The Following 7 Users Say Thank You to PhatFreshPrince For This Useful Post:
DeathEvil (12-12-2021), DocWalt (12-21-2021), Falken86 (12-13-2021), joemysterio (12-20-2021), Lonewolf (12-12-2021), Pete (12-12-2021), StE92ve (12-12-2021)
Old 12-12-2021, 03:44 AM   #2
DeathEvil
Drives: 2022 BRZ Manual Ice Silver Metallic
just got the mirror today, and was planning on doing it tomorrow so perfect timing cheers!
DeathEvil is offline   Reply With Quote
Old 12-12-2021, 07:25 AM   #3
emce
emce's Avatar
Drives: 22 BRZ Limited
Would you mind testing if your Homelink buttons work? Per this thread, there's suspicion that the wiring harness or something about mirror isn't quite right and homelink universally isn't working yet:
https://www.ft86club.com/forums/showthread.php?t=147755
Theoretically, if it works, when you push one of the homelink buttons you should get an orange LED to light up under the mirror (eg, you should be able to see it through the mirror's surface) on the lower left hand side.
Thanks!
emce is offline   Reply With Quote
Old 12-12-2021, 08:16 AM   #4
PhatFreshPrince
Thanks!
Yes, I forgot to test the HomeLink. I will do that today.
The Following User Says Thank You to PhatFreshPrince For This Useful Post:
emce (12-12-2021)
Old 12-12-2021, 09:22 AM   #5
CZ6T
Drives: 2022 crystal white BRZ
My hide was chapped when I took delivery of the car back in November because I had bought a camlock style frameless JDM mirror in advance, just to have them change to a wedgelock style on the 22
CZ6T is offline   Reply With Quote
The Following User Says Thank You to CZ6T For This Useful Post:
PhatFreshPrince (12-12-2021)
Old 12-12-2021, 01:16 PM   #6
StE92ve
StE92ve's Avatar
Drives: 2014 Mazda CX-5
Very nice DIY. Does anyone know if the GR86 can use same mirror and has the same wiring in the overhead?
StE92ve is offline   Reply With Quote
Old 12-20-2021, 02:02 PM   #7
PhatFreshPrince
Could you give me a link to where you got your frameless mirror? Mine is having the HomeLink not working issue, and I might return it of a better one.
Old 12-20-2021, 05:55 PM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
@PhatFreshPrince did you ever test if the homelink part works?
Old 12-21-2021, 09:19 AM   #9
PhatFreshPrince
Yes, the HomeLink is not working for me. There are no lights or anything on. I will let the dealer check it out after the holidays.
Yoshoobaroo (12-21-2021)
Old 01-05-2022, 11:05 AM   #10
CZ6T
I got mine from Toyota directly, it's PN SU003-07866
but it won't fit onto the windshield directly, either you'd have to change the mount or find an adapter, which I wasn't able to find.
Old 01-05-2022, 11:55 AM   #11
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
That's for the older model, correct?
Old 01-05-2022, 11:59 AM   #12
CZ6T
Correct, all the way up to 2020. I assumed, in error, that Subaru would keep the windshield mount the same for the second gen, but they did not.
I don't know of a frameless mirror option for the 2nd gen at this time.
Old 01-05-2022, 12:06 PM   #13
dragoontwo
dragoontwo's Avatar
Toyota shows one for the GR86, but I haven't been able to find the part number for it yet.
Old 01-07-2022, 03:06 PM   #14
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
So Is the homelink issue fixed? Or does it require dealer BCM flash?
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
vignesh is offline   Reply With Quote
DIY: Auto dimming rear view mirror install Longhorn248 DIY (Do-It-Yourself) Guides 64 01-21-2021 07:17 PM
Auto Dimming Compass Mirror With EVERYTHING For Plug & Play Install Face_Plant Interior Parts (Incl. Lighting) 8 03-22-2019 11:18 PM
Auto Dimming Mirror from Subaru with HomeLink or not? reynierpm Cosmetic Modification (Interior/Exterior/Lighting) 9 02-13-2018 09:49 AM
FS: Subaru auto dimming homelink mirror dmarkey Audio/Visual, Electronics, Infotainment, NAV 15 03-12-2015 03:25 PM
Subaru brz/scion fr-s auto dimming mirror w/ homelink & compass Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2013 01:36 AM
